Windshield Haze w/ Rain
eskimochaos
Banned
I'm having a problem with windshield hazing when I use the windshield wipers. When the wiper makes a pass over the windshield, it creates a haze that last for just a second and then it disappears as if it evaporates. Then when the wiper makes another pass, the cycle starts over. Wiper cleans the windshield, haze appears, haze disappears, wiper cleans windsheild, etc..
The problem is really bad at night when meeting oncoming traffic. The combination of haze and headlight glare makes it impossible to see the road. What can I do to fix this problem? I Any thoughts?
I don't treat my windows at all, they get an occasional Windexing but usually just normal car wash.
Any recommendations, Im trying to stay away from Rain-X due to streaking when using the wipers.
I use rain x never had a problem with streaking and will definately fix the problem that you are having. Good Luck
You dont have a problem with streaking when using the wipers w/ Rain X on the windshield?
Thanks! I will give it a try.
I had streaking with Rain-X until today when I bought a set of Rain-X wipers retail about $20. The streaking is gone, but I still get some what of a haze. Good luck let me know if Rain-X works for ya.
That's what I'm worried about, Im going to try deep cleaning it before anything. Things Im going to try before RainX
Vinegar
Coke
Specialized Cleaner
0000 Steel Wool
I don't treat my windows either. I get no hazing when it rains/snows. I use Prestone De-Icer (yellow) for my reservoir along with the defroster plus bottom (80-85 degrees) on. And during the summer, i use the (green) Bug Remover.
eskimochaos, try the rainex washer fluid. I have never had streaking or hazing when using it and it acts just like the stuff you wipe on the window that gets hazy.
Hope it helps,
Well just went to PepBoys and got Stoner Invisible Glass and RainX. Applied the stoner twice than the RainX twice. The RainX definitely works but there is still some hazing with initial testing (throwing water from water bottle on windshield) it is supposed to rain sometime this weekend, I will report back then. If this doesnt work, I heard its a ***** to remove RainX from the windows.
I find that when you first put Rain-X on the windshield, it can haze. You can remove it by lightly spraying with water, then polishing with dry newspaper. Once you remove the haze, I've never had it haze during a rain.
perhaps an obvious question, but how old are your wipers? In my experience wipers have three phases to their lives... when new there's very little hazing, when they're a bit older the hazing starts, when older still the hazing turns to streaking.
I've never used Rain-X but I do often dry my windshield with newspaper. A car dealer taught me that decades ago. Seems to do the trick.
I change my wipers right before every rainy season here in CA and even after only four months or so they start to get worse. I'd change them twice a year if it rained during the summer, too.
I don't know about SF but down here in Socal the smog eats them. What you get is a layer of "dead" rubber on the blades., I just take alcohol on a towel and clean them till no more black comes off on the towel. That will work for awhile.
Just went from 8 month old Bosch Icons to Bosch Excel + thinking that was the problem - it wasnt.
Not sure about smog up here but I know the CA sun/heat kills rubber pretty quickly. Hardens that nice flexible blade edge in no time... by mid-summer my new wipers are already shot and barely good enough for windshield washing duty.
I find that car washes with the wax treatment will cause haze.
Windex and windex the blades. The blades hold crap in them, clean them very well.
I've always had good results before changing blades with a good cleaning with Bon-Ami cleanser.It's super mild but will cut the scum thats' built up on the glass.The RainX window cleaner is what works for me, on several vehicles over the years. I haven't looked around for anything else, probably as good or better stuff out there though. Save the RainX for the exterior, I like either Clearveiw or Stoners for inside.
Any link to Bon Ami...can I get it at Pep Boys?
Don't know about PepBoys but most grocery stores have it,normaly it'll be with the other cleanser types like SOS and Comet. One thing I've learned is when you use it keep it good and wet and rinse it well. It's too mild to scratch but rough enough to cut the build-up.Can't remember just where I first heard about it, may have been on one of the ''car nut'' sites like Autophia or AutoGeek......good luck!
