Windshield squirters, LOW pressure.
Easy to remove tank and all. Four bolts two hoses. The filler neck just pullout. Check for chunks the the reservoir. Clean it out along with lines. I think the pump also has a small screen on it to keep the big stuff out.
Is there supposed to be a seal or a gasket between the neck and reservoir? I was refilling mine yesterday for the first time (only had the truck a few months) and the fluid came pouring out of the spot where the 2 parts meet..
Yes it's a rubber ring that goes around the lip in the hole in the tank. The spout fill funnel goes inside it. The spout is held in place with a bolt. I suppose the rubber could be inside your tank. Even if it is in place the fit is not real tight.
FIXED IT! I opened the hood and it squirted out with full pressure so I unclipped teh hose at teh hinge and gave it a little slack and it works like new. I wish I would have tried that before I bought the squirters, now I feel dumb.
Pictures? Mine squirt with low pressure sometimes, and normally at others. It seems to happen when I use it for the first time in a few days, so I assume it's clogging nozzles, but I could also see it being something similar to what you had to do.
Edit: Cool. 1000 posts, yo.
I didn't take any pics, but if you open your hood you'll see the tubing on the passenger side. Just unhook it and give it a little slack.
leolediola
