Windshield Washer Reservoir Filler Neck to Tank Rubber Gasket
BestNThDez
My windshield washer fluid tank is leaking from the black rubber gasket, that is located where the filler neck inserts through the top of the reservoir. Question is, does anybody sell just a replacement gasket? If not, does it come with the reservoir tank or the filler neck? Where is the best place to get the gasket, or tank/neck if I need to go that way?
my windshield washer fluid tank is leaking from the black rubber gasket, that is located where the filler neck inserts through the top of the reservoir. Question is, does anybody sell just a replacement gasket? If not, does it come with the reservoir tank or the filler neck? Where is the best place to get the gasket, or tank/neck if i need to go that way?
8533630160
Thanks for the info
Which year and model vehicle did you get this microfiche picture from? My dealer is saying that the part number you posted doesn't fit a 4Runner, only Avalon/Camry...
I understand that it may transfer over and fit, but just wondering, as they are saying it's not for my vehicle.
Thanks for the info
The pic was from Lakeland Toyo, but I reverse searched, and it is the wrong pic.
From the pictures I've seen, it looks like the gasket you're referring to is part of the reservoir but could be wrong. I didn't see a part number for just the gasket. The washer filler neck and reservoir have 2-3 part numbers that state are compatible with 96-02 (2.7 & 3.4) 4runners. Guess you could call your parts dealer to find out the differences with the part numbers.
Washer filler neck:
8530135010: ~$55
8530135020: ~$62
Washer reservoir:
8531535241: ~$29
8531535261: ~$52
8531535271: ~$52
Washer cap:
8531633050: ~$5
Ok thanks for all of the help. From what I have been told by other people, the lack of a separate part on the microfiche, and from the dealer, it looks like it is part of the reservoir like "FourFive" mentioned. I'll order a reservoir today, or go to the junk yard/Pic-A-Part.
