That link above did nothing but give me a headache.:redbrick:
Bump for this question.
I would also like to know if anyone has solved this issue of having not only all the 12 V outlets always on but the 120 V AC outlets as well as?
you can't have the 120v A/C outlets "on" without the engine RUNNING.
The Power Outlet (12V) (2010 4Runner) document shows how the outlets are wired to the fuse.
The Power Source (2010 4Runner) document on page 5 shows where that fuse gets power after the ACC Relay.
Looks like you could just move the supply of the P/OUTLET fuse to the violet wire to get it to be on with the ignition, or to the black wire to be on all the time.
I haven't done this, just looked at the schematics.
I did the full time 115 AC mod as one of my first modifications. I am sure you can apply some of the info on my page in combination with the 5th gens FSM and get it to work. It does come in handy at times like for example when you are out and about using the digital camera alot, you can charge in in the rig during lunchtime for an hour or so and be good to go.
I'm not seeing these documents
hmm... I think it was part of the PDF Repair Manual download.
Excellent write-up. I would bet the relays themselves are the same (even if they are in a different location), so this write-up will probably give me what I need!
Did you ever do this mod? I would love to be able to have these plugs hot all the time.
