Wiring Strobe Controller help!
DLH87
I purchased a strobe controller (https://www.superbrightleds.com/mor...obe-controller/1105/2620/#/tab/Specifications) to hook up to some Kawall amber LEDs.
Ultimately, I'd like to have the lights be able to turn on and off with a switch and then if on, the option to strobe with this controller (which has the last-pattern memory feature). However, the diagram provided by the vendor only shows how to run the strobe controller directly with the lights, meaning if the light was off, i could only turn it on with the controller to the "always-on" mode, and if i wanted to strobe it, I would have to cycle through to whichever pattern I wanted.
Is this even possible?
I hope that made sense! Thanks in advance for any help!
Don't think its possible to do this...
You could use a diode that only allows current 1 way and have the lights on a separate switch for steady burn and then hook this controller up to strobe. But you would have to turn the steady burn off to have it strobe.
If your willing to spend some more money... Feniex has some that have 2 modes. So you can have 1 mode on steady burn and the other mode on strobe.
https://www.ultrabrightlightz.com/f...tm_source=bc&gclid=CODunqjYtdICFdgKgQodGbYOTA
yes this is possible
just make the output from the controller go through a SPDT relay that connects either direct power or control (that will to to your mode switch). Power the 2 circuits through a DPST relay (that will go to your off on switch).
Fish4runna
