Won't go into Overdrive!!!
Dominic G.
I have a 94 4runner with a v6. On cold starts, (even after letting it warm up) it will not go into the high gear - (overdrive) running down the road. NOW if I run about 3 miles or so with the engine warm now -- I stop the 4runner take it out of gear turn the engine off for maybe 3 seconds, turn it back on and then the engine will go into the high gear (overdrive). There has to a sensor that has gone bad.!. It runs fine after I do that.
Anyone out there that can help?
:help: :help: :help:
When was the last time you checked you Tranny Fluid? When was the last time it was changed? How many miles are on your truck?
Cheers,
