Would this be a good on-board air set-up?
vthokie
Hey guys I'm working on building an on-board air set up for my 4Runner. I want to be able to air up my tires, and hopefully operate air tools. I recently bough the Overland Heavy Duty A/C so all I need now is the tank, a pressure switch and some air tools/ hoses.
The compressor is capable of 150 psi, but i dont plan on having my set up run at that high of a pressure.
The compressor can draw up to 45 amps, but the pressure switches that I found with built in relays all have 40 amp relays. How would this affect my set up?
Here are the parts I am looking at using.
Tank
Amazon.com: Viair 2.0 Gallon Tank 150 PSI: Electronics
Tank fittings/plugs
Amazon.com: Viair 90005 Tank Port Fittings Kit: Automotive
Pressure switch 90-120 psi
Amazon.com: Pressure Switch with Relay: Electronics
Compressor
Heavy Duty Air Compressor Kit
Any comments or suggestions?
