Write-Up Tech: Tacoma wheels on 4Runner caliper rub fix
randy88fj62
Member
When you buy Tacoma wheels you run into the issue that the back spacing is different. The Tacoma wheels rub on Sport and Limited Calipers.
If you run SR5 16" wheels then this will not affect you.
Back to the rubbing. DO NOT grind down your caliper. The solution I wound up with is to run wheel spacers.
Certain wheel spacers have an issue where the wheel spacer nuts do not 100% engage your stock wheel studs. To remedy this you need to install longer studs.
Longer studs that fit our truck are readily available:
2003-2006 matrix or pontiac vibe, 55mm long.
AWD matrix stud Toyota P/N 90942-02078
Dorman P/N 610463 from a 2004 Matrix $1.42 each
Philthyphilthy
