4runnerfourplay
I definately want the button but if someone has a working stock inverter I will buy that as well.
Thanks, Tony.
Thanks, Tony.
If you plan to post to Classified forums, you must follow these rules, or your post will be deleted.
boostedprozac said:I don't have one but I saw that at circuitcity, they had a million of them at 75w+ at 40% below retail. Which totals the 175w for like 40 bucks or so.
sant6236 said:Aren't you referring to the AC in the center console? Why would it be wired to the area in the rear? I dont understand.
sant6236 said:The inverter is located behind a trim panel? Why would it be located there if no one can access it to plug into?
What am I missing here?
I thought the 115AC switch operated a optional inverter outlet within the center console that some models have.
sant6236 said:Ok, nice that makes sense.
So, truly there are (3) parts to it, the switch, receptacle and invereter?
So how would you hook an aftermarket inverter up to the OEM switch?
