XenonDepot Super Sale! HID kits - Starting @ $94.99! LED Bulbs! Much much more!
Here is your chance to win a FREE Apple Ipad 16GB Wifi. Simply subscribe to our HID Kits blog for your chance to win! Our blog will feature information about the products that we carry. Subscribe to be made aware of new products, detailed reviews, and awesome pictures that our customers have submitted to us! Many of the questions you may have about what is involved in upgrading the lights on your vehicle with our HID kit or our automotive LED bulbs is readily available right on our blog! You will also be emailed about any last minute promotions that will enable you to save even more!!
Good Luck!!
Steve
XenonDepot Guys-
2007 SR5 4R here.
What 5000k kit do I need to upgrade my fog lights? Any heat issues to worry about?
What yellow LEDs do I need for the front and back turn signals? Worth the upgrade?
Thanks. Sorry if this has been answered... Long thread.
Hi pmdata,
As per your questions:
1) Your vehicle uses a 9006 bulb for the fog lights meaning that you would need to order the 9006 fitment when getting a 5000k HID Kit.
2) LED Bulbs:
Your vehicle uses 4157 bulbs for the front turn signal. This is the Automotive LED bulb I would suggest getting for the brightest possible output:
3157 LED Replacement Bulb, Putco Neutron LED Replacement Bulb - White
Your vehicle uses a 7440 bulb for the rear turn signal. This is the bulb I would suggest for the fronts:
7440 LED Replacement Bulb, Putco Neutron LED Replacement Bulb - Amber
You will need to wire in resistors to simulate a load when upgrading your turn signals to avoid a "fast flash"
Coupon Codes Available:
HID Kit: Make sure to use coupon code T4R upon checkout to save $25
Automotive LED Bulbs: Make sure to use coupon code T4RLED to save 15% on your LED order.
Hope this helps,
Steve
Thanks Steve. I appreciate it.
Before I order:
"Coupon code "T4R" is not valid. The coupon expired on Thu Sep 30 00:00:00 PDT 2010."
Am I doing something wrong?
Pete
Hi pmdata,
2) LED Bulbs:
Steve
Last question, from the manual, the bulb for the parking lights is a 168. would this work?
194 LED 360° Replacement Bulb - White - Replaces part numbers 168 194 2825
And my fron turn signals are listed as 1156NA. Is this the same as a 4157?
Thanks,
Pete
Hi Pete,
Thanks for responding.
1) The coupon code will work now. Sorry about that.
2) Parking Light - Yes, that bulb will work. Truthfully though, I would take a look at this 194 High Power LED bulb for the brightest possible output.
3) Turn Signal - We do have 1156 LED bulbs. For some reason, my application guide shows otherwise though.
Steve
Just ordered my second kit from you guys. This time it's for my girlfriend's Mazda 3, though it uses the same H11 bulb as 06+ 4th Gen's.
The kit I ordered for my 4Runner took 2-3 weeks to arrive due to short staff. If you can make sure this order goes through a little faster I'd really appreciate it since it's a gift for a specific occasion/date. (A little over a week from now).
-Josh H.
I am new to all of this and want to put HID in my wife's 2008 4runner. I know I need the H11 kit, but which kit is best. Other question is our 4runner has daytime running lights so do we need to disable those prior to installation of the HID kit?
Honestly I am not sure....I will have to take a look when my wife gets home....Any other 4runner owners care to chime in?
HB 4x4 - You have a PM :)
Got the PM but I figured I would reply here so anyone who comes across this thread doesn't get worried.
The tracking info was updated in the account info on your site, I am just used to receiving confirmation e-mails when packages are shipped out. The kit should be here Monday. Thanks for following up.
milgrad - do your Daytime Running Lights operate off the Low Beams or the High Beams?
You're referring to the amber DRL's right? The HID kit doesn't affect them. Our DRL's are the same lights as our turn signals so they are unaffected unless the kit has changed and now taps into the harness somehow.
The kits are plug and play. My first one only took me about 30 minutes to install which included running the wiring under the plastic radiator cover.
Hope that helps.
Hid conversion?
Okay so i got a 1990 4runner with the stock h6054 sealed beams! Are those upgradeable? Also with some night trailing i found the need for more light so i went and bought some off road lights that have a standard 100w h3 bulb. Is it possible to fit or modify these for hid and will it be brighter?
matisgugle
