XM Radio
rajeev
I already have XM in my 5th gen, but I'm getting a new HU now. Do I need to get the full XM radio kit, or can I just buy an adapter and set it up since I already have an antenna. Please help!
You can definitely use your current antenna, each radio has a specific radio id. Dependent upon your head unit you may/may not need the brains behind the scenes to run satellite radio. I assume you aren't installing this head unit yourself? If you are/aren't, ask the place where you are purchasing. Or, might want to give a quick ring to your closest Best Buy, the install person should be able to answer any questions you have...
Hope that helps.
