Y Adapter part number for Sirius
cover8
Would like to have the part number for the "Y" harness in the pic below...this harness will for clean installation of the sirius recvr in the stock 2005 4Runner Nav...
This site http://bruce.pennypacker.org/sirius-highlander/ reports the part number as:
PTS31-07050
Is this correct? (damn I hope so...cause I just ordered it!)
thats either a toyota sirus connect, or a universal one..
Make sure you have the sirius box, and it has the 14 pin "smart-harness style" plug..
I am sort of ticked because I ordered from Partznet and did not get the right parts
The "fit Kit":
PTS31-00051
...fits the 2005 OEM Nav but the female it connects too is already being used so a "Y" adapter that has a male and female connection must be used.
I currently have the stock male connector not connected to the back of the NAV unit. The results of not connecting this clip is the NAV unit will not go to "night" mode and the lights on the shifter and most (not all) of the AC lights arent coming on either. I think this clip powers the light sensing unit on the dash?
Also, I noticed when removing the console there is one white male clip under the buttons on the shifter console that does not connect to anything or does it? If so, where does it connect?
The Sirius Reciever part #: PTS31-00052
Will the above harness fit this Siruis Recvr? Do I have the "smart" connect type Sirius?
If you dont have heated seats, thats the pre-wiring
Shoot...I do have heated seats! Where does this clip attach then? I could not find a female connection for it. Where is the clip it connects too?
Thanks for your help.
the only buttons that are on the shifter bezel pieces are..
Heated Seat buttons (driver and pass)
and the DAC (is it DAC? Downhill assistance control??)
Make sure all three are plugged in...Besides that..Idk man..
Look 2 the plug, see if it has any marks showing it had been plugged into something..
update sirius
i did install the y connector with the part number in the pic above...the CD player will not play. Sirius works very well and sounds better than CD itself but will not play with the Sirius connector installed.
Has anyone been able to get the CD player to work and the siruis unit?
If so, what is the FIT KIT (wire harness) number?
Damn this Sirius has been a serious PITA!
