Yellow vs. White Fog Lights: Which Do You Prefer for Winter Driving?
lasfit
official vendor
Winter is here, and with it comes foggy mornings, rainy nights, and snowy drives that challenge visibility. When it comes to cutting through these tough conditions, fog lights can make a big difference. But here’s a question that sparks debate: Do you prefer yellow or white fog lights?
Yellow fog lights are known for reducing glare and improving contrast in dense fog, heavy rain, or snow, while white fog lights are brighter and more modern-looking. So, which color do you feel gives you the best visibility and sense of safety when winter weather hits?
Share your experiences and opinions—what’s worked best for you, and why? Let’s get a conversation going to see which color reigns supreme this winter!
these are two good articles on fog lights in general and proper yellow lamps in poor weather
Daniel Stern Lighting Consultancy and Supply
headlamps today are much better than they were many years ago. I've never use my fogs. given headlamps need to be on when using fog lamps, and headlamps are white, they mix with yellow/amber fogs and you lose a lot of the benefit from a high performance yellow fog light mounted properly
fogs can be good to see the edges of the road and combined with headlamps can help some (I have white fog and white headlamps but never use the fogs in any of the many snowstorms I've been in over the years, never felt I needed them). fogs are meant to be used at slow speeds as well. I can see a real benefit if you are offroading and need better edge visibility. the results from those articles are interesting though
I installed the lastfit 22" amber light bar 2 years ago and have been very happy with it thus far. I've had a chance to use it in some blizzard conditions in Vermont and some very thick fog situations (Yellowstone in mid-May). In those situations, I found that using the amberlight bar alone resulted in the best visibility and least amount of eye strain. I've had a chance to do several 12,000 km roadtrips and had ample opportunity to try the light bar, headlight, foglight combinations (on empty roads only). The amber lightbar just seems to cut through the snow and fog in those extreme conditions. And no, the install wasn't sponsored by lasfit.
toyota-4runner.org/5th-gen-t4rs/307059-lasfit-22-amber-light-bar-upper-grill-mount.html
Advantages for both, but yellow is generally better reducing glare and improving contrast, seems to cut through the falling snow better. However you loose full color with yellow. So i split mine so i can still get full color on the road and yellow for more distance/contrast.
Anything up high i would definitely lean yellow like i did with my pod lights.
man I like the look of pod lights when they are on, but damn they ended up getting annoying for me in the winter time and full of snow/ice making windshield cleaning a pain when there was a lot of snow. so I got rid of them. I do miss them though , nice pic
I garage my 4R, but i can see that being a problem with snow. Lucky i went with BaJa Designs which are really small, so far not a problem.
baja are great - had the s2 pros and squadron fog lights - not the street legal ones. that combo was really powerful. but I did go back to stock after 1 or so years.
Have amber Baja fog lights, which are supplemented (depending upon conditions) by a VisionX light bar mounted behind the grille (with a range of lighting pod types). I was won over to amber years ago living in the mountains, but I agree with the other posting: proper aim is critical (and not as simple as one would think).
By testing on the garage door, I know current stock fog lamps are set pretty low, well under the beams of the headlights.
for whatever its worth, i pick out other vehicles in the distance much better if they run yellow fog lights. sometimes its as valuable to be seen, as to see.
youngrk
