KU_MechE
So, i'd like to clarify, the improper way to run Seafoam through the car's intake system is to use a vacuum line that only feeds one cylinder. If you used the brake booster vacuum line, you've only been feeding a single cylinder.
In this picture below, you can see the brake booster vacuum line directly feeds a single runner (either Cyl 3 or 4). This means your Seafoam is not at all distributed to any other cylinder.
In this picture below, you can see the PCV vacuum port feeds the plenum before it divides into the 6 runners. While you'll never get perfectly even distribution, hopefully some of your Seafoam gets to each runner.
