Zak's 03 Limited Build Thread
Hey Zak do you have any picture's of how you ran your LED bar wire into the cab? Or a description of some sort.
I don't have any close ups, but sure I can give a description but all credit goes to [MENTION=77955]jdkilroy[/MENTION] for the method. I used 12G wire and stuck it in the little "gap" down the side of the weather striping and put a piece of electrical tape running the length of the windshield to cover it. I also used a few dabs of silicone to hole the wires in place.
I ran it down the driver side since I put the switch next to my steering wheel in a blank there, relay in the driver side fender and the harness on the light was on the driver side
My bar didnt come with a harness so i'll just solder it running to a relay then to my existing PIAA switch.
hey nipples
when you have time id like to see close up how you mounted the high lift on factory rails?
and is it in the middle or?
Its on the driver side since I was sitting a little high driver after the rear lift. The brackets are from slee offroad mounted on some yakima 10v mightymounts which I got cheap on ebay. The brackets are $$$ and in retrospect you could easily make some with a piece of angle a bolt, but I've been too busy to deal with another project. Also, buy my old headlights :D
How do you turn on your halo rings without having the DRL's on? I have to flick my headlight knob once which dims to activate my halo rings and of course activated when headlights are turned on.
My halos are tapped to a + IGN source so they get power whenever the ign is turned to acc. I believe I tapped the heated seat fuse.
Is this the mount you got?
Slee - Roof Rack Accessories
I was thinking about getting it too but didn't know if it really fit our 4th gens or not. The website just says Toyota OE Roof Rack with no indication whether or not it fits on a 4th gen specifically
Ambrose67
