shinyblackdeer's 98 T4R SR5 V6 build thread
E-Locker is in (plus, another retrofit e-locker wiring diagram)
We've been AWOL for awhile, but not without progress! I had mentioned we found a complete e-locker rear end from a 97 (with 4.30 gears). We then found a front diff with 4.30 gears out of another 97 (thanks to Luke Graham from Frontier 4x4. Jeff spent hours cleaning and refurbishing both. He spent a Saturday swapping the front and a Sunday swapping the rear. Now it's complete and we have a locking rear diff. Awesome!
There are so many write-ups about retrofit e-locker wiring, one more can't hurt, right?
Our 98 SR5 V6 w/ automatic transmission, A.D.D., and w/o 2-4 select switch was not pre-wired for an e-locker. I chose to go the factory route by sourcing the factory 4WD ECU, RR diff lock control switch and rear diff lock wiring harness. For wiring, I used 4-conductor trailer wire plus 2-conductor speaker wire. I also purchased single repair wire terminals from Toyota in order to light both the RR diff lock control switch and the RR diff lock indicator light in the instrument gauge cluster. You can download my wiring diagram here. Note that I have disabled the factory safety features by grounding the SPD and 4WD wires. Here are some key photos that supplement my wiring diagram:
In order to light the factory RR diff lock control switch, I purchased (2) repair wire terminals (82998-12170) and installed them into pins 3 & 4 of the connector as shown. Pin 3 goes to ground, pin 4 goes to a 10AMP fuse tap (see my wiring diagram).
You have to gently pull apart the connector in order to insert the new terminals:
Shown from the back of the connector:
In order to light the RR diff lock indicator on the dash, I purchased (1) repair wire terminal (82998-24180) and installed it into the connector behind the instrument gauge cluster as shown here (looking at the back, far left brown connector). It literally took me 1.5 hours to figure out how to unlock that connector to insert the terminal. You have to separate the inner white housing from the brown connector by depressing small white tabs on both ends of the connector:
Here's a photo tracing the path from the bulb to the pin (I used a new #74 3 SMD red LED wide angle wedge base bulb):
Here shows the 4WD ECU mounted in its factory location (behind driver's side kick panel) and the common ground point.
Here shows the location of the fuse taps used to light the RR diff lock control switch and the RR diff lock indicator light:
Since I already had amp/sub wires running along the driver's side, I chose to route the wires connecting the 4WD ECU and the e-locker wire harness through the center (under the center console). Here shows my spliced wire bundle coming from the front to the back (beneath rear passenger seat on driver's side):
And here shows everything nice and clean:
And the final result:
Thanks to the many online write-ups for help and inspiration, most notably Retrofit Electric Locker and [MENTION=44220]BigFishAllDay[/MENTION]'s awesome wiring diagram, which helped me the most.
Amazing quality of work. Props for doing it right. So wish I had the cash flow to move at this rate. I admire your attention to detail.
Thanks to the many online write-ups for help and inspiration, most notably Retrofit Electric Locker and BigFishAllDay's awesome wiring diagram, which helped me the most.
Glad I could help! I like the wiring diagram that you put together, too. It makes mine look like it was drawn by a kid with a box of crayolas.
I would have liked to wire in a dash indicator light the way you guys did, but the gauge cluster on my '01 doesn't have that provision so I had to go with a separate LED.
Nice work on the 4Runner as a whole, btw. You two have put together a sweet rig.
Thank you! The devil is in the details, though. It feels like we've been working on this thing Forever.
Thank you! I truly appreciate the contributions you've made to this forum.
You guys are doing a fantastic job. Many hats off to you both.
Blue
Thank you so much!
I finally got the interior back together and it smells awesome! Here is the Shiny Black Deer testing the Coverking seat covers. Doberman tested, Doberman approved.
It's been a few months since you all installed your seat covers. How do you like them? Have they "molded" to the seats better and lost the wrinkles? I am interested in buying some of those and wanted to see what your thoughts were.
I'm still very happy with the seat covers, and yes, they have "molded" over time. I ordered a yard of the same fabric and plan to revisit my center console armrest cover, plus recover the fabric on the doors and door armrests. I would definitely recommend Coverking.
Would you mind posting some additional photos of the seat covers?
Thank you.
Not my best photos, but hopefully you'll get a better idea of how the seat covers fit. The rears definitely fit tighter than the fronts:
Hood painted!
Jeff took vacation last week to finish the home projects we've neglected this summer in favor of the 4Runner. He did, however, squeeze in a day to paint the hood. This time he had the paint custom-matched to the truck, rather than using the factory color as with the bumpers and flares. The match is nearly perfect. No spray bomb this time — he brought the paint gun out of retirement. As usual, he did an awesome job.
One of these days we'll have some action shots, not just garage/driveway shots.
Thank you for the pictures. I was hoping the fronts would fit a little better. I have been reading about these seat covers, and they sound like what I want.
Another front diff, this time with an RD90!
I wish our timing were better, since we just bought and installed a front diff with 4.30 gears a month ago, but we couldn't pass this up:
Thanks to Casey, aka [MENTION=51127]Dous[/MENTION] for this awesome setup and for the giant envelope of stickers! I do love stickers.
[/QUOTE]
The fitment of the bumpers are amazing! Noticed that especially, as those are the bumpers that have grabbed my attention for my '99. The detail and quality of the rest of your build is equally superb. Great teamwork to the both of you. Hard work pays great dividends and you'll be happy you worked so hard when the weather goes south (so to speak). Truly inspirational. THANK YOU for all the great pics and detailed (and humorous) commentary! It's builds like this that make this forum so invaluable!! Subscribed
The fitment of the bumpers are amazing! Noticed that especially, as those are the bumpers that I have grabbed my attention for my '99. The detail and quality of the rest of your build is equally superb. Great teamwork to the both of you. Hard work pays great dividends and you'll be happy you worked so hard when the weather goes south (so to speak). Truly inspirational. THANK YOU for all the great pics and detailed (and humorous) commentary! It's builds like this that make this forum so invaluable!! Subscribed
Thank you -- we appreciate your kind words!
We extended the three 18" #2 gauge solenoid cables with new 54" #1 gauge cables (to reach the solenoid mounted inside the engine bay). This little tool came in handy for attaching new lugs.
Solenoid mounting location (right below the battery tray).
do you have any further details (and photos) of how/where exactly you mounted that Solenoid? did you have to fab a special bracket?
Sorry for my delayed response. I don't have better photos than what I posted, but you'll have a better understanding if you remove your battery and battery tray. The M8000 came with a mounting bracket for the solenoid. Jeff drilled and tapped the frame with an 8mm - 1.25. He mounted the solenoid to the bracket, then did a test fit to mark the holes. There's plenty of clearance down there.
Thanks for all the likes, btw.
Philthyphilthy
