Fuel Gauge Off ????
edeuce
OK, wondering if anyone else has had this issue. I just bought a 99 SR5 5 speed 293K on it. i just filled my tank for second time. First time i got like 200 miles to tank, but only put 10 gallons in to full !? So second time i went all the way to empty till low fuel light came on. Filled up again 11.7 gallons 240 miles this tank. ok so i think my truck has 18 gallon tank.? So gauge bad or sending unit bad ??? What ya'll think ??
Mine's the same way and has been as long as I've driven it (~2 years).
'97 SR5 5-speed 189k miles
Average gallons per fill up = 10.83
Average miles per fill up is ~ 192 miles
welcome to one of the only problems the 3rd gen owners complain about. its kinda normal. well if the majority have the problem its the norm.
just old sender units having problems.
Yep.
Me too. Light comes on at about 10 gallon mark. I've run it over 330 miles and filled 16+ gallons. I guess they are 18 gallon tanks….
utEP
Well, just installed Ultra Gauge an its saying 300+ miles to empty ! LOL my just carry 5gl fuel tank around till it runs out to c how far it will go ! haha Thank for info !!!!
Frey, i'm assuming u also 18 gallon tank ? have u ever ran way past empty ?
Ha, we all have 18.5 gallon tanks, right? Never actually run down to empty, in fact... I just looked through my maintenance log and I've never added more than 13.6 gallons of gas and I always fill 'er up.
Is the gauge an issue on all model year 3rd gens? Just picked up a 2002, but I only started driving it yesterday.
:driving:
My dad's 99 some times reads 3/4 - full when in fact its 1/4 - empty.
"Meh", he's learned to live with it.
It's a problem on '99s. There is a TSB on it. (attached). The problem is in both the sender and in the dash. The newer sender also has a vent tube with the air hole in a different place so it actually lets MORE gas into the tank. Don't assume you have a 6 gallon reserve just because you can only get 12 gallons into it. Engine will die while there is still a gallon or two in there and the vent screw-up keeps the tank from getting truly full.
Fuel Gauge
I have a 98 and a 2001 and both show empty with the light around 13gal and around 220-230 miles on the odometer. I usually figure around 230 city miles to a fill up. I don't usually do much out of rush hour driving with them since they are my daily drivers. I recall that they both get closer to 260-275 on the highway before they show a low fuel warning light. Another quirk is the light will present then slowly dim and go away for around 10 miles then stay on seems weird but both show that same behavior :confused:.
I had this issue on my '99 although no where as bad as some people have had it. I did the fuel gauge reset shown below and while it is still not 100% accurate it is much closer. I generally fill up when my gauge is between 1/2-1/4 showing on the gauge to be safe. But I have gone all the way to Enough on the gauge with the fuel light showing and still had multiple gallons left in the tank.
This information below is not mine, I found it on the 1st yotatech link below. After I did mine I noticed the gauge change from the prior reading and it is much closer now that it was prior.
Electrical EL010-99 99 & 00 4Runner
Vehicle has to be sitting on a level surface with an inclination of +/- 0.5 degrees.
1.With the ignition switch in the Off position, press and hold the trip speedometer reset button.
2. Continue pressing the reset button while turning the ignition switch to the On position.
3. Within 5 seconds of turning the ignition switch On, release the trip switch, press trip switch 3 times and on the 3rd press, hold the switch for 5 seconds. The buzzer will sound for 1 second at 800HZ.
4. After the buzzer stops, release the trip switch.
5.Press the trip switch one more time and hold for 5 seconds. Once more the buzzer will sound for 1 second at 800HZ.
Worked like a charm on mine, hopefully it will work on yours too!"
it also worked on mine, i was so confused on how i was gettin 25mpg pulling a loaded trailer till i was stuck on the side of the road. gauge was reading over half a tank so i couldnt figure out why it wouldnt run. (a 4runner dont run on faith) i was out of gas. after a new fuel filter, that it needed anyways, a couple of shots of ether and a few knocks on the gas tank we realized it was empty. followed the steps above and the gauge reset properly. no problems since
Fuel Gauge Issue? - YotaTech Forums
3rd gen fuel gauge problem: I think I figured out the problem (pics) - Page 3 - YotaTech Forums
Bringing this back from the dead since I can't start my own thread yet.
I have a 99 4x4 LTD with 220k ish miles. Just purchased.
I've gone through almost two tanks of fuel now and the fuel indicator (wiper) has never moved off of E. Even more strange is that the low fuel light is NOT on.
I have researched this on the forum a lot. Like mentioned before, the fuel gages seem to be pretty inaccurate. The TSB mentions doing the calibration (which I have done twice now) as well as replacing the 3rd circuit board in the dash cluster and the fuel sender and pick up tube.
However, since my fuel gage light is not lit and because the wiper has never moved, I'm wondering if maybe the fuel indicator wiper itself if broken? Has anyone ever troubleshooted that before? Thanks in advance.
I'm trying to be strategic without just throwing parts at the vehicle. I am going to check the resistance values at the fuel sender assuming I can get to it under the passenger rear seat. Seems like some years you have to drop the fuel tank to get to it?
[MENTION=147387]dirtysouthjacket[/MENTION]
I know it sucks, and no offense, but I'm glad to know I haven't thrown my money away trying to fix mine cus it seems like it's almost an irreversible problem. I'll just keep resetting my tach every new tank.
ive never used my fuel gauge, throw that money at an ultragauge and use that. its been extremly accurate to where i can gas up with almost the exact amount. i usually just ask for a dollar more than i need just to be sure. ultragauge is about $80
Yeah, if it was just for me I wouldn't worry about it. Resetting the trip meter is how I have to do it on some of my bikes that have no fuel gage at all. However, since my wife will be driving the 4Runner occasionally, well....
I guess she'll only run it out of fuel once before she learns! Lol
I haven't had a problem with that.
I have a 2001 SR5 with 168,000 miles. Gas gauge is pretty accurate. Right when the light is on I fill up about 14 gallons and if I drive like 20-40 miles on the light I can fill up like 17 gallons.
so it's pretty accurate
The prior owner may have pulled the low fuel light bulb. I did it to mine b/c it was so annoying. I solved the problem by using an ultragauge.
The ultraguage gives you a readout on your gas tank levels? So the 18.1 is how many gallons you have in your tank currently and it calculates it as you drive?
correct. and its very accurate. only gauge that is accurate on my dash is the rpm. the temperature gauge is also innacurate. it stays the same from 160 degrees all the way to 225. then it will move lol my speedo is off cause of the 33s so i have that calibrated into the ultragauge. right now it says i have 14.2 gallons, my current gas price is 2.49. so i would need $4.30 to fill it up but i usually round up just in case and its been great. very close.
PRWhite
