No. A spark plug was severely stuck in the number 3 cylinder. I tried everything, p b blaster, yield, finessing it back and forth, soaked it with penetrating oil over night, heat, finally I gave it the onions and broke the nut off the threads. So it gets even better... Got a screw extractor, removed what I could of the broken plug and tapped it into the threaded section of the plug. Tried to go easy, then a little more, then finally the screw extractor broke... So now I've pulled the valve cover in hopes to get closer to the thing and the tubes are in the way. I've watched a few videos on how to remove them but none for the runner.. so I was hoping someone had ran into this before and knew how to get the tubes out.
Ah, I see what you're saying. I haven't have the 'pleasure' of pulling the tubes out of the head.
Good luck with it and with getting the plug bits out!
It was actually Sunday..
I had to do an oil change on the girlfriends TDi Beetle so decided I would do an oil change on mine too.
I spilt oil everywhere... I really did relocate my oil filter to the most retarded place ever. :lol:
Did the projector retrofit using mini d2s 4.0 square projectors. Loving it thus far.
what ballasts did you use? was everything from the retrofit source?
I was on 36, a quick 4 hour commute from Denver to Boulder. It was something else.
Ouch. I left my house at 6 and it only took me maybe 20 minutes to get to Boulder. Sat at work for an hour or so waiting for the rest of my coworkers from Westy/Broomfield.
I did Transmission fluid change flushing system with onboard pump.
12qt of Valvoline Max Life used with roughly 8 Qt left in system.
New crushwasher.
Odd find,
I checked fluid level on level surface no under/over present yet 4qts came out of pan during change.
I’m thinking this was due to good warm up & parked for 3 hours on steep incline for change.
Anyway , my 96 4-runner winter work is complete.
I Replaced all Fuel injectors on driver side , full coolant system flush & Trans fluid.
All work was done outside in 30-40deg temp wicked wind chill @ times cold cold cold.
NEVER AGAIN
Grill Mod
Took the grill off my 2000 4RUNNER and used a small saw and dremel to cut out all the center plastic. Will be putting in mesh grill and TOYOTA emblem sometime next week.
Got the old girl some fresh wheels off a 2018 Tacoma. Running 1.25" spacers with them as well.
Figured I'd take another step along the way of refreshing the A/C system considering I've had the dash torn about since September. Have all the parts (or so I thought), just need to do it. Pulled the evaporator core out, seemed like it could use a little refreshing. The bolts holding the expansion valve and tube assembly were just rusted in to the point of no removal without damage. So, Camelback for a new tube assembly (already have the expansion valve).
Valve cover gaskets...
Oh man.. that's on my list of stuff to do.
I read the thread that mentioned "check tightness and hand tighten down any loose bolts first" and did that. several were loose so I thinkkkk I bought myself some time and can just wait til dry weather to do it.
Nice work though
P0304 = tires?
Offered designated driver duty to haul the crew to a brewery tour 2 Thursdays ago. Hit the onramp, engine started missing, CEL flashing, ScanGaugeII found no codes, re-routed back to get another car, on to the brewery! After the festivities, the Snoop threw a P0304 on the way home. I visually inspected #4 spark plug and wire, switched out the coil packs, still P0304. Yeesh, injector? head gasket? yikes. Sputtered over to a mechanic for diagnostics - bad spark plug wire. They offered to replace the wire set and plugs for another $600 beyond the diagnostic fee. They also recommended a new air filter, even though mine is a) clean and b) 700 miles young. I declined and handled it myself at an order of magnitude less money and 47 minutes to complete the work. Lessons:
  • Genuine Toyota spark plug wire set is worth the price over the Bosch wire set that crapped out in 21,000 miles. It's a lot beefier with protective wraps in all the right places and includes all the clips, pre-installed.
  • Find my multi-meter or get a new one and use it. It's a lot cheaper than the diagnostic fee.
  • Find a new mechanic... again.
I immediately justified new tires with the $$ I didn't hand over to my previous mechanic. Ordered Costco Bridgestone Dueler A/T Revo 3s with that all-important M+S symbol (our DOT demands proper tires for mountain passes and such). So, I suppose I'll find out soon if the Snoop likes his new shoes.
I am sorry, did you say $600 for plugs and wires?:lookout:
