The 3rd Gen All Questions Allowed Thread
I've already replaced the OEM Solenoid B, filter, pan gasket, and ATF. Wiring checks out, but the same code came back.
Transmission shifts well around town with no slipping or harsh shifts. Highway symptoms are no overdrive, no apparent torque converter lockup, and RPMs drop immediately when lifting off the throttle. Also have a faint whine that changes with RPM/vehicle speed and is only present in gear.
Transmission shop suspects the valve body. Has anyone had a persistent P0755 after replacing the solenoid? Did it end up being the valve body, torque converter, internal harness, or something else?
I just replaced timing belt, water pump, theromstat, and the other belts on my 2000 4runner.
As well as the rad as it was leaking when I filled it back up.
Anyway, I have discovered a leak of coolant then steam (when it's warmed up) coming out of this orifice on the block.
Is it missing a plug? I don't see any tube that would connect to it.
Does the head head bolt above it tighten or loosen the plug? v6 engine.
I believe the bolt to the left of that port opens and closes the coolant passage.
Hey everyone.
I am trying to replace my exhaust on a 98 SR5.
The front exhaust pipe and cat are one piece and I am looking for suggestions on right side bolt access.
I had to use a breaker bar to bust the left two nuts and stabilizer nut loose but the right side is harder to get to. I dont have a straight shot at it. The up pipe and swaybar bushing mount on the chassis are in the way so I cant get anything on it from underneath like the other three I got loose.
Any help would be greatly appreciated.
Hey everyone.
Long extension and a wobble socket.
Guys,
Been a long time!
The steering in my '99 Limited has some... issues.
Occasionally, it feels like it is binding inside the column, behind the steering wheel... it makes gritty/squeaky/grindy noises during the stiff times.
It's not the rack, not the ball joints, not the steering shaft coupler... every one of them moves freely.
I haven't yet removed the steering wheel, to look for any other the moving parts, but I plan on doing that next.
I'm not sure where else to look for the culprit!
Has anyone faced this issue? And if so, what was it?
Guys,
Been a long time!
There is at least one bearing and one bushing in the steering column, here's all the parts for the steering...
Just a moment...
Hi, I joined for advice on selling my beloved 2000 4Runner Limited. I have driven this car for 25 years, but do not need it anymore. It has 277k miles on it. Where should I sell it and how much should i ask? I haven't modified anything.
cant find the part number that gets you the pair at a lower price of buying each from toyota ? It was like their "warranty package"
I need to get a discontinued part for my 3rd Gen 1999 Toyota 4Runner LTD and I am wondering if there are any non-discontinued parts that I can use instead. Only the plastic tabs broke, nothing more.
Part # is 84830-35041 which replaced 84830-35040 so either would work for me.
There seems to be similar parts that look like they might work, but eBay's part fitter says no:
84830-35050 4Runner Sequoia 2003-2020 Liftgate Release Switch
84830-34010 Tailgate Lock Switch 2001-2007 Sequoia
Anyone know if these or some other non-discontinued part number will work?
This one?
84830-35041 Genuine Toyota Tail Gate Switch Assembly
Thank you for replying. Yes, that is the same part number I posted.
FWIW, in hindsight I realize I should have mentioned that I already placed an order with them and I am waiting to find out if they will actually be able to fulfill on a long-discontinued part.
Or as I suspect from past experience with other website retailers (e.g. yoshiparts.com) they just advertise all possible parts, take any order they can get, and then try to source the part from wherever they can find it which, for a long discontinued part, is almost always nowhere.
BTW, they have lots of disputes on the BBB website) and they seem to be well know for not holding inventory but instead source parts from dealers and then cancelling orders when they cannot source it.
I asked them via their chat to verify they had in stock and they would only repeat that they would email with within 4 days that the part shipped, implying they will also email me to cancel the order if they cannot source it, which I fully expect to be the case (though I will HAPPILY be wrong if they are able to source it.)
Given that I fully expect they will not be able to deliver, I wanted to see if I could find alternatives I could use that have not been discontinued for when the (IMO) inevitable email comes telling me they are unable to fulfil the order.
I bought a raggedy ass SR5 99 4Runner from auction and the previous owner apparently had a knack for bullshitting, after much work on the front end I eventually thought about doing a "quick" front diff fluid change when I ran into the tightest, stripped out drain plug I've ever encountered. I've already tried heat and just hanging on it like an ape, is there any wizard shit I can perform or should I just air chisel it to shreds with another case on standby?
Weld a nut onto it and unbolt the welded nut is probably the best last resort
Keeping myself honest, turns out Genuine OEM Toyota Parts and Accessories Online - Toyota Parts Deal was able to deliver the part I needed, even though it had been discontinued.
Premature alarm on my part. Mea culpa.
Hi all, my steering rack boot has been ripped for some time and it finally has started leaking and I’ve noticed a lot more play in my steering. The boot is just leaking out grease so my seals are likely still ok but I need to investigate the steering play and replace the boot itself. However I am moving back to college this week and have a 16+ hour drive. Wondering if anyone has thoughts on if this is something I should deal with before or if I can deal with it at college?
I would also love an info/videos on how to find which steering component has play and needs to be replaced.
averyberryman061493
