Automatic Running Boards Issue
Does this happen with the car off? If the car is being started when the running board deploys or stores, this will cause it to fail to deploy or store, as the car starting is taking most of the available power. If storing fails once you start to drive the board will retract at 5mph as a safety feature. If you avoid starting the car right when someone opens a door or within 3 seconds of a door closing this may solve your issue. I don't think they make this clear to owners in the documentation and likely why the dealer can't recreate the issue.
No it does not happen with the car off?
just had this issue on my 5th GEN 2016 T4R LTD ... auto-running board problem ... first the driver-side started acting up ... it would extend no problem, but wouldn't retract until i hit 5mph or so ... several months later, the passengers side starting exhibiting the same problem ...
took it to my dealer here in colorado ... nearly broadway/littleton blvd ... at first they wanted to replace both motors (first, they were both working - kindof, 2nd, odd that they both go out at/near the same time) ... anyway, they got the motors in (under warranty), replaced them ... same problem ...
their tech got on the horn with toyota's tech ... turns out to be defective ECU (controlling the running boards) ... motors were fine (which makes more sense) ...
they put the ECU's on order ... i'll update more after the parts arrive ...
btw, both motors if replaced after warranty ... $1602 per side ...
just a follow up on my ECU replacement ... working perfectly after ECU (not motors) replacement. i suspect (with no evidence) the ECU's are failing because of where they are mounted (underneath the 4runner, near the running boards) ... perhaps they're exposed to weather/conditions where they don't hold up based on location?
The running board ECU is actually in the driver's side footwell behind the fusebox inside the car. It also has a pretty interesting coating over the chips inside the box that appear to make it somewhat waterproof. I didn't closely compare the two to see what the difference is in chips.
thank you ... i stand corrected
You can get fixed running boards, the old ones just un bolt. The only issue is the rocker panels. Get ones that are compatible with limited or modify rockers. There are threads here with resolutions.
I'll give you $100 for that new ECU :)
Knowing that it could still go bad, i'm holding onto the ecu for now :)
With my luck i'm going to need it, just like i'm starting to replace the failing door lock motors. Luckily those were a really cheap fix.
My Auto Running Boards (ARB) just started acting up ( 2012 T4R LTD): Driver side won't stow ( but attempt to) until car is moving ( @~5mph). By looking at replies above it looks like the cause is NOT the motors but either lubrication or ARB controller (PN 89720-35011).
Found a TSB 0278-17 about ARB but it looks like , if there is any movement of the board, the TSB does not apply (otherwise, TSB would recommend replacing the Side Auto Step Controller PN 89720-35011 - $240 at https://www.toyotapartsdeal.com )
I am hoping someone has a repair/service diagram for electrical or mechanical components... or any material ( even photos) that will help with disassembly or help identify safety module location, ARB controller (ECU) location...
Would also help to know if replacing ARB controller would require additional dealer configuration/setting ( with custom software).
Could not find anything on this subject no matter how much time I spent on Google
Any info would be appreciated.
Thanks!
My Auto Running Boards (ABR) just started acting up ( 2012 T4R LTD): Driver side won't stow ( but attempt to) until car is moving ( @~5mph). By looking at replies above it looks like the cause is NOT the motors but either lubrication or ABR controller (PN 89720-35011).
Found a TSB 0278-17 about ABR but it looks like , if there is any movement of the board, the TSB does not apply (otherwise, TSB would recommend replacing the Side Auto Step Controller PN 89720-35011 - $240 at https://www.toyotapartsdeal.com )
I am hoping someone has a repair/service diagram for electrical or mechanical components... or any material ( even photos) that will help with disassembly or help identify safety module location, ABR controller (ECU) location...
Would also help to know if replacing ABR controller would require additional dealer configuration/setting ( with custom software).
Thanks!
Automatic Running Boards.
Fixed my problem - Easy
I have a '15 Limited here in Michigan with 64k miles. Two winters ago the auto running boards started acting up like many of yours. Sometimes hesitated stowing and deployment. Sometimes you had to step on it to trick it to stay out. Anyway, they were an expensive option back then( I think $1500) so I was not going to give up and just remove them. Then eventually put up with the ones that stick out all of the time. To make a long story shorter, I took bicycle chain oil with the little straw and squirted the oil in all of the joints and hinges that I could find. Apply to your satisfaction. Bicycle chain oil I just happened to have but I think binds less dirt and dust. Probably most important is where the motor mechanism is. I haven't had any problem with them since. Its been almost two years now. Every 6 months or so, I apply the oil for lubrication.
Good info, I never thought of doing that. I'll give it a try as well. I have a lift and had to remove the mud flaps because they rub. Ice builds up there and causes issues but I had issues prior to the lift as well. Ended up having one side replaced under warranty.
Modification?
Folks,
Has anyone tried to remove the trim piece on a Limited and raised the running boards up higher? Wanting to get a little more ground clearance...or are the boards set/designed to be a certain way and can't be changed.
This is great info. I'm going to give this a shot. My '13 Limited is just starting to have issues with the driver's side. It works maybe 19 out of 20 times, but every once in a while the driver's side doesn't deploy when I open the door. I can then close the door and reopen and sometimes the running boards will come out the 2nd time. When I am driving alone I turn them off because I don't use them, but my two young kids need them for now.
White Lightning chain lube might be interesting to use. It's a wax based lube that flakes off to shed dirt. Regular oil based lube is still going to cling dirt to some degree.
The negative is, it needs much more frequent lubing.
I'm looking at a 2021 Limited. I have an Escalade with ARBs and they are wonky, so I'd rather not repeat that issue. Can you order a Limited with something besides ARBs, or are they pretty ubiquitous?
Issues with Passenger Automatic Running Board on 2016 4Runner Limited
I like the 4Runner had a 2005 SR5 and liked it so much purchased a 2016 4Runner Limited. Runs great, but now the passenger RB is coming halfway out when opening the Passenger Door and sometimes the RB comes out and stay out until I drive off and retracts after I reach 5mph.
Anyone have the solution for this issues?
Someone said give it a good cleaning at the joints with a pressure washer and lube it. If it has resistance it won't retract. I tried this but it didn't solve my problem.
The first time it happened I took it to the stealership under warranty. They replaced the motor and some other stuff. It was about $1300 to repair but under warranty. Next time I'll just replace them with fixed boards.
Love my 2016 Limited, but a love hate relationship with my Running Boards
I'm brought my 2016 new and loved the RB from the beginning, but now they have a mind of their own. I'm in cold Michigan. They act up during the summer and winter. So I know it's not just a snow and ice issue.
I have sprayed them with WD40 to keep them lubed
Anyone have any suggestions?
They usually come on the Limited versions. Nice option if you have someone that can't step up into the SUV without some help.
Thanks, I will try this today.
erinobr2000
