Sunroof Blew Out!
On a side note, whatever happened those? Last I heard the military scrapped trying to replace the Apache with the Comanche and just left it at that...
Just because you bought it from the dealer like that doesn't mean its "stock" a lot of the 4th gen guys had "stock" 4Runners from the dealer where they installed an aftermarket sunroof in before the vehicle went on the front line. Just to inform you. :)
Thanks but don't all Trail Edition 4 Runners come with a factory sunroof?
Well its been a few months but here's an update on the situation:
I ended up buying a new piece of glass ($850 Canadian), which apparently was the Dealer's cost.
Add another $150 for install.
The install shop did a poor job because they didn't vacuum out the old glass. I just found this out by operating the sunroof. I just took it back to the shop to get them to pull it out again and remove all the old glass.
Everything works fine except when I'm sliding the glass pane forward, to close - it hits the arms from the bug shield and then stops and goes back to open. I think it's getting too much friction on these arms and the safety kicks in. The shop has no lube to put on. So now I need to see what Toyota uses to lube the tracks of their sunroofs to help it out a bit. I'm thinking silicon spray won't hurt.
What a long ordeal.
Yes - Toyota said it likely had a chip in it before the blow out. There was no getting around it other than writing a letter to the President of Toyota. I didn't have the time to fight it so I just sucked it up and paid.
That article is mildly humorous! When mine blew out, I was laughing. I thought it was the coolest explosion ever, until my brain realized that it was going to be costly.
It may or may not have been a rock chip. Who knows. It's over now. I just hope it doesn't happen to others.
I'll have to look into the driveshaft thumpy thing, Intruder. I think I know what you're referring to, as I've heard something like this in mine before.
Here you go man...
http://www.toyota-4runner.org/5th-g...s-fix-axle-wrap-driveshaft-clunky-thumpy.html
Don't say it Marc...
Me in my 2016 sr5...wtf?
(had trouble with the audio - but yes sounded like a gunshot)
YouTube
Apparently there's a class action suit about them changing the glass supplier and this becoming more frequent?
YouTube
I’m not a lip reader but I got a feeling that I know exactly what you said in that video.
Glad you’re ok and didn’t cause a collision.
Same same & thanks! - i was doing 70+ which is a rarity in socal/santa monica
You never know how you'll respond in an emergency so happy with this one.
They don't last for 6 or 7 years then fail. You probably had a micro crack or a chip t that grew and the pressure was just enough to pop it.
I had my cat crack my windshield. It was find by what I could see, then he cracked. Was from a tiny little chip that compromised the integrity.
Tx470
