3rd Gen T4R DIY Maintenance, Repair and Modification Videos
Rear Door Window Glass Replacement
If you're ever in the need to replace your door window glass, this video will walk you through the steps to get it done. This was done on a rear door but the fronts will be very similar.
<iframe width="560" height="315" src="https://www.youtube.com/embed/I2y7QxqNkLU" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Does anyone have recommended tools for someone that doesn't have to purchase? What are your go to tools?
I have bought most of my tools via Amazon because of the pricing and convenience. I usually let the reviews drive the decision whether I'll buy a particular brand. If the reviews are good, I'll usually go for it.
Brands that I own a lot of tools from are as follows:
Dewalt
Milwaukee
Gear Wrench
OTC
Lisle
Knipex
You can spend a lot on tools but the great thing is they save you money over and over again so they are a solid investment.
I have a master list of tools I have purchased over the last 5 years.
Timmy’s Master List of Suggested Tools - Google Docs
If you're just getting started, I would highly recommend you get a nice set of ratchets in all 3 sizes, 1/4, 3/8, and 1/2. The flex head 120 click point ratchets from Gear Wrench are awesome. You'll need sockets, standard and long in 1/4, 3/8 and 1/2 as well. You'll need extensions in all those sizes too.
Get a set of flex head ratcheting box end wrenches. Again, Gear Wrench is a good choice. These wrenches really save you a lot of headaches and time.
A good impact gun is nice unless you like the workout. Dewalt makes nice ones and so does Milwaukee.
I could go on and on with tool suggestions but that's a start. Good luck! If you have questions, go ahead and personal message me.
To caveat off of Tim ^ there's no reason to get SAE size sockets unless you plan on wrenching on something not imported and older than 2000. Most vehicles will be metric after 2000 and I think all imports (or at least asian vehicle imports) are metric.
Total Chaos Weld-on Spindle Gusset Install
This videos explains the steps to get some Total Chaos Spindle Gussets welded on.
<iframe width="560" height="315" src="https://www.youtube.com/embed/j_huaSfp3Vs" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Opt Off Road Rear Control Arm Install
If you wheel hard, you might be interested in upgrading your rear control arms to something a lot more beefy. [MENTION=102606]infamousRNR[/MENTION] , my partner in crime with our Timmy the Toolman YouTube channel installed a set of these on his rig. Check out the video and be ready to drool over these things of beauty.
<iframe width="560" height="315" src="https://www.youtube.com/embed/bAymvyHLifQ" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Hey guys I can’t start a new thread because my account is still new but I was hoping someone could help me out? I discovered this wire unplugged coming from behind/ under the center dash/ under my glovebox and have no clue what it is . My 4WD hasn’t worked and no light has come on the dash since I got the car and was hoping maybe this was possibly the fix . Thanks for any answers !
By the way I have a 2001 sr5 sport with the electronic push button 4WD
You can post your questions on here The 3rd Gen All Questions Allowed Thread.
Provide some better pics showing of the plug.
2000 Toyota 4Runner Limited...where can I purchase cigarette-lighter replacement sockets with USB ports?
in your fuel injector video you dont mention the differences between years. I have injectors that are motorwest, that were ordered for a 2000....yet might need to put them into a 98. Some places say not interchangeable....some say ok as long as all 6 are done so electrical draw and flow rates are the same. some list same injector 96-2002, and I forget what perfomance place sells 1 style for all years that are supercharged that have higher fuel flow.
Some say it will mess up the ECU to run the newer injectors in the older engine and ecu.
Thoughts or comments ?
I also posted this question on the youtube video of yours but figured i might get the answer and more input here
a sincere thansk for all you and sean do and making these videos....thanks
The flow rates are different minutely and the spray patterns 99-2004 is better. Motorwest from 2000 should work fine in the 98.
Hello, I just purchases a 1997 4runner and would like some recommendations on what kind of preventive maintenance I should do first?
Lower ball joints and radiator if mileage and condition are unknown. Pull back the top timing cover and look at your timing belt to see if you need to replace that or not. If you need a timing belt make sure to get all the pulleys/tensioners required, a water pump, and a new thermostat. It would be a good idea to flush the cooling system before radiator and/or water pump replacement. It's quite likely that your valve cover gaskets are leaking as well. If they are make sure to do the camseals and half moons when you do the valve covers. A new fuel filter is pretty cheap. Check your spark plugs and wires too.
Here's a helpful tool to search the 3rd gen section for whatever you may be looking for: site:toyota-4Runner.org/3rd-gen-t4rs/ - Google Search
plugs denso dual électrode k16tr11 or ngk dual electrode BKR5EkB-11(were like 4 bucks at auto zone) or Toyota 90919-91192 , ngk wires NGK (4412) RC-TE66 Spark Plug Wire Set around 30 bucks on Amazon.
Clean maf and replace air filter if dirty
PCV valve Toyota 12204-62010
It's time to build! 3d Gen 4runner
Hello 3d Gen 4Runners!
I am finally getting around to working on my SR5. I am the second owner of this 4runner, that spent its entire life in the desert of New Mexico. I have spent the last three years either in the Middle East (Iraq, Syria, Kuwait) or where I have lived in Germany. My sister has kept it garaged in her house the whole time.
I can't wait to get to this project. Before I left I had timing belt/water pump/etc. done. I think where I will start will be to get underneath and start looking for all the rubber pieces that may have been dried out from spending all those years in the dessert - any suggestions on where to get replacement parts? I will to plugs and wires right away, and do a fluids (oil and cooling; thoughts on doing transmission flush?).
I will post another picture, but the clear coat had gotten really bad (I bought it this way). I love the forrest green (does anyone know the actual name or paint color of this?), and want to restore it. I do not think it actually needs paint but likely a clear coat restoration.
Before I do the paint, what would you suggest that I do first to the exterior. I do not see a whole lot of snorkels, but I do like the look of it (and the utility, though I am not sure how much water crossing/heavy dusted trails I will be attempting).
Next, as I mention snorkels, I want to improve the airflow. Suggestions on breathers, and exhaust? Is it worth it to get a header down exhaust? How about the intake - how can I improve this?
Major mods - I have a ski boat and I am looking at small tow behind campers. I haven't driven the 4runner in years, but I recall it having decent power. However, I just got back from Germany where I was driving a 550hp Audi S6, with the Lamborghini 5.2L V10 on the unrestricted highways (autobahn). Getting in the 4runner for the first time is going to feel like I am got shrunk in Mario Cart. With johnny law and speed limits in America, this is probably a good thing. I do want the power to get 4 people and the boat ahead of a truck from a highway on-ramp though. What can I do for power?!
I bought new tires before I left, though I cannot recall what they were. I am not really looking to lift it, but would like to have a level stable ride. What can you tell me about improving the handling?
I recall the headlights being deplorable. I think I remember holding my cell phone light to navigate in the dark. Has anyone done a HID or LED headlight swap? Does just buying a new stock setup help (after 22 years..)? I think I have a rock chip in the left headlight that actually exposes the headlight chamber to the elements. What else helps improve lighting? Suggestions on mounting aux lights? I've always liked the idea of having a switchboard to toggle a bunch of lights. I thought with the color of the car, some super yellow lights might be cool (go Pack, go - Wisconsin native here).
I took this beast camping and anchored a hammock to the crossbars on the roof rack. It was strong enough that even my girlfriend at the time and I could sit in the hammock no problem. My fat ass friend took a 30ft running start to jump into the hammock and the crossbars exploded off gloriously. Watching him hit the ground as hard as he did was almost worth it, but finding new crossbars and anchors has proven to be harder than I thought! Before deploying I went to about half a dozen junk yards looking for bars (after seeing they had 4runners in stock) and they had ALL been removed already (and not hidden away with the junk yards for excessive markups). Any ideas to get these replaced? The rails are fine, and I would consider rack - potentially something that could support a rooftop tent setup, do these exist?
I am thinking about anywhere between $5k and $7k worth of mods to get rolling. My sisters and I are buying a lake house, and I want this to eventually become the old reliable at the lake-house. I have stage IV cancer at 34 years old and am not sure how long I will be around - but I hope that this ride gets another 20 years and 100k miles.
Thanks for reading! If you have any input, please let me know :).
