front wheel stud replacement
fastolds
how hard is it to replace? Is there a way around disassembly of the front hub bearing? I have access to a bearing press, if necessary.
Any other tips or tricks?
Thank you.
Remove the caliper, remove the disc, pound out the stud, put the new one in from behind the hub. Can all be done if you remove the disc - about 20 minutes total time.
TerryNap61
