Bolts on torque converter/flexplate
DPR64
Installing a new motor and was bolting up the trans and saw that there is a 'green' bolt that needs to be installed first? I did no use that one first, do I need to redo it all? Why is it to be installed first??
2000 4runner 4x4 auto 3.4 liter..
The FSM doesn't really say much about it other than use it first. I would assume it's slightly different than the rest?? Maybe the shaft is a little smaller to allow some play to get the rest in easier? Just guessing since I've never taken a trans out of one of these.
I just went ahead and re did it... seems like that odd colored bolt is a centering bolt and has less play in the hole than the others...
