*** 10AC's Speed Build Thread ***
10ac
2000 Toyota 4Runner 4WD Auto 3.4l
When i bought it in 2013:
Current as of 2-19-2014:
added the rack
rola roof rack and Supercharged it! TRD gen 2 black w/ stock pulley and dynamic tensioner. while i was in that area, i did the timing belt kit with water pump OEM.
also did the sir mod and deck plate mod. as well as ngk plug wires and coil on plug boots and denso ik22 plugs will be doing the URD 7th soon!
How's the rola rack working out for you? I've heard mixed reviews, seems like people either have no issues and love them or they rust in the first couple months
Well the rack was 130 shipped. I liked it because it was low profile. Mounting was easy and was look i wanted. Its a good priced rack and sturdy. I will tell u as soon as u get it, scuff it and paint it. The coating they use is weak. Mine is starting to rust around the welds and mild corrosion at the top of the bars. But for 130.... No complaints here. Just buy few cans of primer and some semi gloss black and its good. Got it i think from etrailer.com
pics of lift parts etc.
so came across a 4xinnovations front plate bumper. i originally had did a hid conversion on my stock fogs in my factory bumper and did a morimoto projector retrofit as well with black painted internal as well as the parking side marker lights. i then got rid of them by working a deal with my buddy for his 4xinnovations bumper, thanks [MENTION=83885]Dirtyfingers[/MENTION] !! here are some pics below, and like i said, this is just a speed build thread showing building of my t4r. i just finished most of the lift this past weekend, before that, it was nearly stock. i was running daystar 1 1/2 spacers and tall rear coils with monroe struts.
stock fog lights with fully weatherproof conversion hid 6k
removed factory bumper, on with new
lift parts and sliders etc...
so i decided to order the lift. i actually got a good deal on brand new sway away coil overs. 2.0 series extended length. got those and purchased the bilstein 5100 series rear shocks, OME 891 rear springs, trail gear dom tubing sliders from [MENTION=80392]Wheeler[/MENTION]'s Off-Road, Inc. , Thanks Josh for the deals!! Just reminding everyone, they do for sure offer some of the best deals on what i purchased.
while doing all this shopping....
i have been having issues with high rpm pinging and high gear low rpm ping and knew i needed the URD 7th injector. purchased one new and while [MENTION=83885]Dirtyfingers[/MENTION] and i took the trip to LA to get the urd 7th, i picked up a mint set of TRD headers!! they look nearly new and come with all new gaskets etc for mounting.
rough pic of the headers, few pics borrowed, but ill get more when installed which ill do when i install the body lift so i can raise a little higher to access everything easier.... if i decide not to install them, ill just sell them.
wheels and tires...
just got the wheels and tires... i went with 16x8 pro comp series 7031. 4.5 backspacing. didn't like center caps so i left them off.
tires are goodyear duratracs. 305/70r16. rubbing a little toward back. gonna do 1" body lift and cut back corner out if needed. i love the size and will do whatever it takes to have them!
front lift.. and big brake kit and the wheels installed.
sway away racerunner 2.0 extended length front coilovers.
wheels and tires mounted and lift done!
lift and wheels and tires.... body lift soon to come. i also will be soon installing brand new OEM toyota lower ball joints, outer and inner tie rods.
coming soon......
*oem inner and outer tie rod ends
*oem lower ball joints
*22" led cree light bar to mount on front bumper
*rear led cree 6 cree led light set to mount on rack facing back
*led cree round lights for front bumper round light mounting holes
*toytec 1" body lift
*2 piece front skid plates
*winch
*e-locker
Thanks y'all for checking out my "speed build". y'all have a great day!!! and wheel on!!!!!
Man you have been busy!
i have been for sure! trying to get this thing trail worthy!! Im almost ready Brian so you and i and trevor and whomever else is ready we can all maybe do a overnight run!!! You should stop by soon or ill swing by there to grab those bumpstops soon. thanks man
