Old 12-28-2015, 10:27 AM #1
Bandit Runner's Avatar
Bandit Runner Bandit Runner is offline
Bandit Runner is a jewel in the rough Bandit Runner is a jewel in the rough Bandit Runner is a jewel in the rough Bandit Runner is a jewel in the rough
Anyone replace a stud in a Spidertrax wheel spacer?
So I went to rotate my tires recently for the first time since the tire shop installed them. I had trouble getting one of the lug nuts off. After finally getting it off, it was obvious that the tire shop had cross threaded the lug nut on the stud of my Spidertrax wheel spacer. Both the threads on the stud and the lug nut were severely damaged.
So I purchased new lug nuts and a set of replacement studs from Spidertrax.
How difficult is it to press out the old stud and press in the new one? I don't have a press, so I was thinking about using my small benchtop vise, but not sure that would be strong enough. I emailed Spidertrax and they said its better to use a press so that the stud goes in straight.
Any good thoughts on how to get the old stud out, and press the new one in nice and straight? Or should I take it to a shop to have it pressed in?
I appreciate any advice.
Bandit Runner, 2021 TRD Off Road Premium
Build Thread: https://www.toyota-4runner.org/5th-g...ild-2-0-a.html
Bandit Runner is offline   Reply With QuoteReply With Quote
Old 12-28-2015, 11:06 AM #2
cashmoney cashmoney is offline
cashmoney is on a distinguished road
Hammer the old one out and hammer the new one in. Take you longer to get the tools out than to do it. I used an air hammer on the bronco this weekend to knock the studs out and back in. 5 minutes for 10 studs.
1989 Toyota 4runner
cashmoney is offline   Reply With QuoteReply With Quote
Old 12-28-2015, 11:36 AM #3
No concerns with the stud not going in straight?
Old 12-28-2015, 11:39 AM #4
Nah. Lightly tap it in place, check for straightness, if it's straight then go to town. If it's not pop it out and try again. Studs are usually pretty self centering. Would be fairly difficult to drive it in crooked.
1989 Toyota 4runner
Old 12-28-2015, 01:14 PM #5
jasonochs25 jasonochs25 is offline
jasonochs25 is on a distinguished road
What you said, plus when the lug is tightened, itll pull the stud straight if its off slightly (not noticeable)
jasonochs25 is offline   Reply With QuoteReply With Quote
Old 12-29-2015, 12:08 AM #6
Singtoe's Avatar
Singtoe Singtoe is offline
Singtoe will become famous soon enough
Singtoe's Avatar
I made a Vdo while back.
http://youtu.be/TtNb9wKG08U
1999 Limited 4runner in Silver - 9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap - AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers & adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax - Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes - V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in Silver On 37's and Guns for sale
Singtoe is offline   Reply With QuoteReply With Quote
Old 12-29-2015, 12:31 AM #7
nissanh nissanh is offline
nissanh is a jewel in the rough nissanh is a jewel in the rough nissanh is a jewel in the rough
I think there are some groves on the stud and the hub/spacer (more like a slip-york). Make sure they line-up.
Old 12-29-2015, 12:45 AM #8
D Farms's Avatar
D Farms D Farms is offline
D Farms is on a distinguished road
D Farms's Avatar
basically:
hammer out old stud
position in new stud, make sure the splines line up.
on the stud side put washers a lug and a bit of oil on the studs threads and the washers.
use an impact gun to pull it through, this will ensure that its straight as well.
'02 Toyota 4Runner SR5
E-Locked | Geared | Mid-Travel | 35s | Armored | 100% Chooched
D Farms is offline   Reply With QuoteReply With Quote
Old 12-29-2015, 07:36 PM #9
Thanks guys. I'm going to give this a shot tomorrow.
Old 12-30-2015, 10:32 PM #10
Originally Posted by D Farms View Post
basically:
hammer out old stud
This worked fantastic! Thanks so much!
Old stud hammered out (with new stud next to it):
(I noticed that the new stud has much shorter splines than the old one.)
The setup for the impact gun to pull the new stud through:
I didn't get an after pic, but everything is back together and I have 6 studs and lug nuts holding my wheel on again.
Spidertrax Wheel spacer questions 04BCT4RLTD 4th Gen T4Rs 40 06-24-2019 08:23 PM
Snaped wheel spacer stud (ALL-Pro) David_D 3rd gen T4Rs 14 06-08-2015 03:57 PM
FS: spidertrax hub centric wheel spacer. Keemonrunnin For Sale: Non-T4R Items 0 06-17-2014 05:36 PM
Replace rear wheel stud benormous 3rd gen T4Rs 4 09-21-2009 06:42 PM
