Old 01-13-2018, 12:22 PM #1
Lamer's Avatar
Lamer Lamer is offline
Real Name: Jake
Lamer will become famous soon enough Lamer will become famous soon enough
Lamer's Avatar
Real Name: Jake
"The Sequel"
1996 Toyota 4runner SR5
As she sits
Bit of background: previously owned a 2002 SR5, 270K miles, very mild build but was a ton of fun. Regret Selling it. But now that I have had time to really think about what I want in a vehicle, I have chosen to get back in to the game with .....THE SEQUEL........
The Sequel [1996 SR5, 250K miles, $,3800], is going to be a long lasting daily drive/weekend camper/get stuck every once in a while vehicle for me. I Bought it in Sacramento, and road tripped to Houston via Tuscon, and Big Bend National Park. the road trip gave me insite to the issues that exist, and areas to improve upon.
Condition As purchased:
250,000 miles
Revtek 3" spacer lift with original springs/shocks - REMOVED AND UPGRADED
Clear coat gone on the hood, chipped on the fenders
Driver's seat mounting nut was cut out, still have the nut, self tapping screw is now holding the corner down.
Front seats torn and stained badly - REPLACED
Front passenger door did not open from outside - FIXED
Aftermarket wheels, not sure what kind, still a 16" wheel with 285/75/16 tires 70% tred REPLACED WITH TACOMA STEEL WHEELS
Rear Hatch struts are shot - REPLACED
Driver door, when unlocked with key, does not unlock the other doors
Rear window wiper blade is missing - REPLACED
Radio Antenna is missing
To make it livable, and more comfortable for the road trip, I did a few things:
- cleaned old dirty carpet,
- scrubbed, cleaned and installed "new" sporty seats from a 97 SR5 I found in a Pick-n-Pull
- replaced non retracting seat belt with Pick-n-Pull SR5 fully functional seat belt
- basic maintenance: fluids, check belts, battery check, rain-ex...
- fixed front pass door handle
- SeaFoam in the gas tank
The plan now, is to bring The Sequel back to safe, fully operational status, and improve upon from there.
Lamer is offline   Reply With QuoteReply With Quote
Old 01-13-2018, 12:23 PM #2
Lamer's Avatar
Real Name: Jake
Lamer's Avatar
Real Name: Jake
Modifications and Maintenance
Underbody:
Wheels and Tires:
  • Stealth Custom Series F5 - Bronze
  • 285/75/16
  • 1" Trail Gear wheel adapters (spacers)
Front:
  • Tundra YY/YB coils
  • Bilstein 5100 Struts
  • Duralast Upper Ball Joints
  • OEM Lower Ball Joints
  • Wheel bearing, driver's side (previous owner)
  • 1" Diff drop (previous owner)
  • New OEM brake lines
Rear:
  • OME 890 coils (page 3, post 39)
  • Extended brake line
  • Differential Breather Extension
  • Whiteline control arm bushings
  • EimKeith Panhard Bar Correction Kit
Steering:
  • Duralast Tie-Rod end links
  • 555 Tie Rods
  • Energy Suspension Poly Bushings
  • Steering rack guide replaced
  • Intermediate Steering Shaft Replacement (page 11, post 153)
  • New OEM Steering Rack and Pinion (page 11, post 156)
Engine Bay/Drivetrain:Interior:
  • Sport adjustable seats from 97 SR5
  • Scangauge 2 LINK (Ripcord's THREAD has details for getting trans temp.)
  • AMERICA turning knob
  • Late Model Center Console, with switch plate (page 5, post 69)
  • Weathertech floormats (love these)
  • KillMat sound deadening on floor, all doors, rear quarter panels. (really makes a difference, its ridiculous)
  • Window Belt Felt replacement (page 8 post 112)
  • LED interior map, dome and cargo lights
Exterior:
  • FX-R 3" HID Projectors in TYC clear lenses and housing (page 8 post 118)
  • Satoshi Grill with "TOYOTA" lettering
  • Air Ram Intake Snorkel
  • Strong Arm Lift Supports
  • Hood w/ Scoop
  • Rear bumper vent replaced with OEM PT#62940-35010
  • Whitson Metalworks Roof Rack (page 7 post 99)
  • LED Reverse Lights (page 7 post 100)
  • Cadillac Horns (page 8 post 106)
  • LED Tail lights
  • Monstaliner entire exterior - Grrrraber Blue - LINK
To-Do/Wish List:
  • 4:10 geared E-locked rear diff
  • Wet Okole sear covers LINK(1996-98 SR5 Sport Adjustable Seats)
  • JDM Rain Guards, or WELLvisors rain guards LINK
  • TRD Radiator cap
  • Coastal Offroad Front Bumper LINK or Shrockworks LINK
  • Hilux body mount tire carrier (in my dreams)
  • King Coilovers
  • Window tint with 4" windshield tint
  • Rock Sliders
  • Side marker lights
Maintenance / Major Dates Tracker:
  • 250083 miles - Purchased January 4th 2018!
  • 254120 miles - DR & Pass UBJ & LJB + Bilstein 5100 struts + Tundra TRD YY/YB coils
  • 254200 miles - Poly Steering Rack bushings + Late Model Rack Guide
  • 254929 miles - Pass CV Axle replacement
  • 255980 miles - Sylvania Silver-star Ultra Bulbs
  • 255030 miles - Texas State Inspection + Oil Change (Synthetic) + SeaFoam Spray down intake and in gas tank
  • 255660 miles - Valve Cover Gaskets + PCV Gromet
  • 257840 miles - Cleaned blower motor fan (disgusting) (page 7 post 91)
  • 258890 miles - Replaced Timing Belt + Water Pump + Crank seal + Cam seals + drive belts
  • 258904 miles - Replaced Battery with Duralast Gold (Sept 3, 2018)
  • 260001 miles - 2012 Tacoma steel wheels + 255/85/16 BFG KM2's
  • 260623 miles - Oil Change (Synthetic)
  • 263000 miles - SCS Bronze wheels + 285/75/16 BFG All Terrain's
  • 264000 miles - 170degF Thermostat + Walbro 190lph fuel pump installed
  • 264080 miles - Intermediate Steering Shaft Replacement
  • 265030 miles - New OEM Steeking rack installed
  • 265870 miles - TRD Supercharger + URD 7th Injector installed
  • 266128 miles - TransGo Shift Kit install, external trans cooler, trans temp sensor + gauge
  • 282457 miles - Camshaft Position Sensor
Old 01-13-2018, 02:49 PM #3
BigFishAllDay's Avatar
BigFishAllDay BigFishAllDay is offline
BigFishAllDay has a spectacular aura about BigFishAllDay has a spectacular aura about BigFishAllDay has a spectacular aura about
It sounds like you've made a good dent in the list already. It will feel like a new vehicle once you get a fresh suspension under it.
Congrats on the new project, good luck, and welcome to the forum.
2001 SR5 Sport Ed. S/C'd V6 Auto 4wd (< Click for Build) ....everything but a kitchen sink (it's on the "to do" list)....
2003 Tacoma SR5 S/C'd V6 5-spd 4wd (< Click for Build) ....boost, armor, lockers, gears, etc....
2008 Sport Ed V6 Auto 4WD (< Click for Build) ....the Grocery Getter OEM+ build....
My Write ups: T-Case Leak? - 231mm TBU - Rear Axle Seals - Trans. Cooler Install - Suped Up Air Comp - Big 3
BigFishAllDay is offline   Reply With QuoteReply With Quote
Old 01-14-2018, 11:08 AM #4
Lamer's Avatar
Real Name: Jake
Lamer's Avatar
Real Name: Jake
Thanks Fish, really looking forward to this one.
The suspension purchasing has already begun. Decided on the classic Tundra TRD/OME 890/Bilstein 5100 set up.
https://i.imgur.com/WQdryKXm.jpg
The Sequel - 1996 4Runner SR5 - Houston, TX
The Original - 2001 4runner SR5 - SOLD
Etsy Page - Custom Pinstriping and Sign Making
@8LinePinstripe: Instagram
Old 01-15-2018, 10:55 AM #5
Lamer's Avatar
Real Name: Jake
Lamer's Avatar
Real Name: Jake
Bought just about everything for a complete front end and partial rear suspension refresh:
Bilstein 5100 struts (x4)
OME 890 rear springs
Tundra TRD Front coils
Front upper ball joints
Front lower ball joints
Steering end links
Pass CV axle
Need to buy: PLEASE HELP!! where can I get the full set?
Front upper and lower control arm bushings
Rear upper and lower control arm bushings
hopefully going to install this week.
&quot;The Sequel&quot;-image1-jpg
Old 01-15-2018, 01:19 PM #6
Scramble's Avatar
Scramble Scramble is offline
Real Name: Scramble
Scramble has a spectacular aura about Scramble has a spectacular aura about
Scramble's Avatar
Real Name: Scramble
I hope those Duralast boxes dont contain LBJ's. You should only use OEM for those.
Otherwise good luck with her.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
Scramble is offline   Reply With QuoteReply With Quote
Old 01-15-2018, 07:06 PM #7
Lamer's Avatar
Real Name: Jake
Lamer's Avatar
Real Name: Jake
any specific reason as to why? high failure rates?
I purchased the Duralast upper and lower ball joints.
Old 01-15-2018, 10:54 PM #8
Scramble's Avatar
Real Name: Scramble
Scramble's Avatar
Real Name: Scramble
Yea, anything other than OEM for LBJ's has a high failure rate. You should be fine for the uppers. It doesn't have catastrophic consequences when it fails.
Just Google "3rd gen 4runner LBJ failure" & look at the pics. I'm sure it will change your mind.
____________
Old 01-15-2018, 11:41 PM #9
01_4_runner 01_4_runner is offline
01_4_runner is on a distinguished road
what fender flares are those? need to cover some rust for at least the winter untill its worm enough to do some body work.
01_4_runner is offline   Reply With QuoteReply With Quote
Old 01-16-2018, 12:11 AM #10
thecole1098's Avatar
thecole1098 thecole1098 is offline
thecole1098 is on a distinguished road
I have Moog LBJs and they are fine. Just remember to pump about 5 shots of grease every other oil change and you'll be good.
'06 4Runner SR5 V8 2WD -- Flowmaster 50 Delta Series w/ resonator delete | 265/70R17 Toyo Open Country A/T | Pro Comp Series 5044 | Black headlights
'98 Jeep Cherokee Classic -- Fender armor | 35x12.5x15 Pro Comp MT2 | 4.5" RE short arm lift | Locked | Swingout Plate Rear Bumper | Shackle Relocation Kit
thecole1098 is offline   Reply With QuoteReply With Quote
Old 01-16-2018, 01:30 AM #11
audiness's Avatar
audiness audiness is offline
audiness will become famous soon enough
audiness's Avatar
love the color
audiness is offline   Reply With QuoteReply With Quote
Old 01-16-2018, 09:30 AM #12
Lamer's Avatar
Real Name: Jake
Lamer's Avatar
Real Name: Jake
ooh ya good call on the pictures. is the OEM a TRW Ball Joint? hoping to buy this at Autozone.
43340-39465 and 43330-39585 are the part numbers I have for OEM. Can find them on CamelbackToyota.com comes to $215
havent thought of Moog. that might be a good alternatince
not sure exactly, they came with the car. I believe they are the standard SR5 flares for the 96 model. I could be wrong, my flare knowledge is not up to par...
Originally Posted by audiness View Post
love the color
thanks! (I might need to paint, (plastidip) my hood black as the clear coat is completely gone.)
Old 01-16-2018, 11:09 AM #13
Lamer's Avatar
Real Name: Jake
Lamer's Avatar
Real Name: Jake
well, went ahead and bought OEM LBJ this morning. and returned the Duralast LBJ's.
Now just looking for a friend and/or shop to help with the work. hopefully I can manage all of this stuff in one day.
Old 01-16-2018, 03:38 PM #14
Lamer's Avatar
Real Name: Jake
Lamer's Avatar
Real Name: Jake
rear B-5100 tundra bushing swap to 3/4" 4runner bushing
while waiting on a furniture delivery, I managed to push out the tundra bushings, and press in the 3/4" 4runner bushings
the new bushings: Daystar Universal 3/4" ID Hourglass Shock Eye Bushing Kit PN# KU08007BK
all it took was a Tie Rod/Inner Bearing Race Puller, a washer, and a zip tie.
once the first half of the bushing is pressed in, use a tip tie and tie it around the second half. This keeps the bushing from squishing out, and will help force it into the shock hoop. worked like a charm.
a picture of during, and then after, and the tool
&quot;The Sequel&quot;-thumbnail-jpg  &quot;The Sequel&quot;-thubnail-jpg
Old 01-17-2018, 10:29 PM #15
Lamer's Avatar
Real Name: Jake
Lamer's Avatar
Real Name: Jake
Made my way to a couple shops around town today to get quotes on the work below: (I have all the parts, they were quoting the labor only)
replace Upper and lower ball joints on driver and passenger sides
Pass CV axle
both tie rod ends
assemble new front coils and struts
install new front coils and struts
install rear coils and struts
Guess what the lowest quote was..........$1,972.87!!!!!!!!! thats bonkers.
so looks like I will find a shop to assemble the front struts for me, and do the rest of the work myself.
fortunately two of the shops inspected my control arm bushings and both shops said they are ok and do not need replacing. that helps but down on the man hours big time. plus, after replacing nearly everything else, if there is anything funky about my front end, I will know where to start looking.
also discovered my steering rach bushings were very worn. so I ordered a new set off amazon. gotta love free 2 day shipping.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Panman's Build & Adventures- A lot of "Crap, I hope this works" & "Eh, close enough" Panman 3rd gen T4Rs 28 05-09-2016 11:10 PM
NRA Calls Texas Open Carry Protests "Downright Weird" and "Just Not Neighborly" ndcent Off Topic 13 06-06-2014 08:29 PM
Call Him "Spiderman," Not "Antman." Maybe "Lefty." Kraeken 5th gen T4Rs 69 10-18-2013 08:24 PM
WTB: 4th Gen "4Runner," "Limited," and "Toyota" badges James_T Want to Buy/Trade 3 06-25-2011 11:42 AM
Zero point didnt work how to turn off "VSC TRAC" & "VSC OFF" & "ABS" lights sciff5 4th Gen T4Rs 6 09-27-2010 12:10 AM
