5VZ vacuum hose kit.
VernySanders
Does anyone have an extensive list of part numbers for the pre bent hoses, or can anyone point me to a thread on here where that info is listed / a company that makes these? I was thinking about ordering 15ft of silicone hose but then I realized that 90% of the hoses are pre bent. Pesky Toyota. I know I dont absolutely need the bent lines but it will look cleaner with the OEM supplies.
I just went to o'reilly's and got 10' of different sized hoses. they radius just fine and IMO silicone is way overkill for these engines. I run a supercharger and I have never found a reason to go silicone. normal vac hoses seem fine.
you will want 3mm,5mm,7mm if I remember correctly.
otherwise I compiled a list a while back and I know the hose on the back on the air intake that goes to the drivers side head... I can't find a part number for it. sure it exists I just was never able to locate it.
I think once you add up the price for these you will head the generic route, hope it help?
9541110630 HOSE, FUEL, NO.1 (FOR CHARCOAL CANISTER) 2x on this one same part is used in 2 spots
9044512284 HOSE(FOR AIR PIPE)
1734362110 HOSE, NO.3(FOR IDLE-UP)
1730362020 PIPE SUB-ASSY, AIR, NO.1
1734162060 HOSE, AIR, NO.1
1734262080 HOSE, AIR, NO.2
1734362080 HOSE, AIR, NO.3
2382762030 HOSE, VAPOR FEED
1730875010 HOSE, VAC - super small skinny guy for vapor pressure sensor
9099992002 HOSE,VACUUM - evap canister OUT to inta
1226162050 HOSE, AIR, NO.1 - this is up on the air pipe before the throttle body
Okay! I appreciate it! I was thinking silicone only so I never need to do them again because I'm under the impression that it wont crack over time? But I could be wrong. I appreciate that info!! I'll look over it after work / school
I bought a silicone hose kit Made by Mr. Gasket in Silver off eBay for around $15.00 which included different sizes. I was able to do several vacuum hoses and the coolant hose for the reservoir as well as the ones for the windshield squirters with some leftover.
I'm seeing the Mr. GASKET kit is 4mm 6mm and 8mm is this the sizes your kit came with? And did they fit snug?
Hmmm okay I'll keep looking, thanks for the response!
Brand new here, but I'm looking to buy some hoses to replace some that are showing some wear. What sizes did you end up going with? I'm looking to just do them all and not have to worry about them again
I still recommend the silicone hoses for everything except the pcv hose, mine turned from blue to brown because all of the oil lol.
Why does everyone like silicone? Seems like the factory hoses held up for 20+ years.
I guess not all the factory hoses are available anymore. Stupid disposable world.
There are recently compiled lists of still-available OEM P/Ns for vac hoses here on T4R somewhere. Hoping someone will chime in. I want to do as many as I can soon.
I just did all of mine using OEM parts, so I have the full list, including air, vacuum, and fuel hoses. I was able to get all the hoses except three which are discontinued.
When I find some time I'll put the list together and post it.
Were you able to put together that list of OEM parts by chance? I'm needing to replace a bunch of old and brittle vacuum hoses.
Sent from my Pixel 6 using Tapatalk
Yup, thanks for the reminder. Here is the list of vacuum hose part numbers, and clamps, where applicable.
All the ones in green are available, I got most of them from Amayama. A few others I had to source from other places (e.g. Toyota Parts Deal). The ones in red are discontinued.
Note that hose 8 is a generic 90999-92002 cut-to-length Toyota vacuum hose. The part numbers in the diagram also call out the required cut length (e.g. L=150 means 150 mm).
patnewton
