T4rchadly's "RADRNR" build thread (IFS wannabe rock crawler on 37s)
T4Rchadly
CURRENTLY:
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/52844650673/in/dateposted-public/" title="IMG_1104"><img src="https://live.staticflickr.com/65535/52844650673_5b14c45998_z.jpg" width="640" height="427" alt="IMG_1104"/></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/53358396708/in/dateposted-public/" title="IMG_8158"><img src="https://live.staticflickr.com/65535/53358396708_6253927c0b_z.jpg" width="640" height="427" alt="IMG_8158"/></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/53358631120/in/dateposted-public/" title="IMG_7563"><img src="https://live.staticflickr.com/65535/53358631120_c372752266_z.jpg" width="640" height="427" alt="IMG_7563"/></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/52941482256/in/dateposted-public/" title="IMG_5901"><img src="https://live.staticflickr.com/65535/52941482256_ba093b6a46_z.jpg" width="640" height="480" alt="IMG_5901"/></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/52844393209/in/dateposted-public/" title="IMG_1840"><img src="https://live.staticflickr.com/65535/52844393209_eed91da712_z.jpg" width="640" height="355" alt="IMG_1840"/></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
welcome to my build thread and see the start of my 1996 toyota 4runner build. im a mercedes benz technician in Anchorage, Alaska, and planning on moving to colorado this fall of 2019. i recently sold my 1989 pickup in search for a stupid clean 4runner, and just so happened to find a mint 1996 runner. manual trans with 202,000 miles.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47939772702/in/dateposted-public/" title="IMG_2502-Edit"><img src="https://live.staticflickr.com/65535/47939772702_f5798de441_k.jpg" width="2048" height="1365" alt="IMG_2502-Edit"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47939673046/in/dateposted-public/" title="IMG_6478"><img src="https://live.staticflickr.com/65535/47939673046_c3ce6ec6f2_k.jpg" width="2048" height="1365" alt="IMG_6478"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47939672706/in/dateposted-public/" title="IMG_6501"><img src="https://live.staticflickr.com/65535/47939672706_de40e6c393_k.jpg" width="2048" height="1365" alt="IMG_6501"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47939643787/in/dateposted-public/" title="IMG_6526-Edit"><img src="https://live.staticflickr.com/65535/47939643787_4f5dc83d08_k.jpg" width="2048" height="1152" alt="IMG_6526-Edit"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Modifications…
Suspension:
- Front:
- OME struts/ 881 coils
- KINGS extended travel coilovers
- SPC control arms
- Replaced OEM LCa's (stock bushing)
- Toytec 1” diff drop
- Front sway bar removed
- Durobumps front bumpstops
- 333 Fabrication eccentric cam eliminators
- Welded cam tabs to prevent from bending
- Eimkeith strut tower plate/brace
- JD fabrications 3.5 Long Travel kit
- Dirt king 8" limit straps with clevis adjuster
- King offroad 8" coilovers w/ resi's
- Resi mounts
- Modified OEM tacoma balljoints
- Rear:
- OME 891 Coil Springs
- OME shocks
- LC80 black tokico shocks
- LC80 7.5 wrap coils (48131-6A570)
- KYB gas-adjust shocks (LC80 SHOCK)
- Emkeith PCK w/ gusseted upper panhard bracket
- Rear sway bar removed
- Durobumps rear 2.5" bumpstops
- Energy rear link/panhard bushings
- Dobinson c59-210v springs
Wheels and Tires:
- Method racing MR304 wheels
- 35x12.5" Yokohama geolander MT G003
- TRD Pro 17x8 wheels
- Milestar Patagonia 285/70/17 M/T tires
- Spidertrax 1.25" wheel spacers on rear axle
- 37x12.5xr17 Kenda Klever RT
Drivetrain/steering:
- Replaced OEM steering rack
- Wheeler’s Off-Road steering rack bushings
- New Toyota OEM inner/outer tie rod ends and lower ball joints
- Total Chaos spindle gussets
- Extended Breather with filter front/rear
- Mobil 1 synth oil
- Lce heavyweight flywheel (38lbs)
- ARB front air locker with 4.88 gearing (ECGS UNIT)
-ARB rear air locker 4.88 gearing (TRAILGEAR UNIT)
- Marlin crawler 1200lbs clutch kit
- Marlin crawler Stainless Steel clutch line
- 2220 lbs pressure plate with semi-metallic disk
- 900lbs aisin pressure plate, exedy semi-metallic disk
- Upgraded arb compressor to a 120psi pressure switch
- Northwest Fabworks Dual transfer case
- Northwest Fabworks triple stick setup
- Solo motorsports Tie Rod Extensions
- OEM tacoma outer tie rods
Engine and Performance:
- Northstar 27F AGM battery
- "O" chaped TB gasket
- LCE upgraded CC injectors
- Genuine Toyota Block heater
- ARB high output compressor
- LCE upgraded alternator
- "Big 3" wire upgrade (4gau)
- CS144 cadillac alternator
- Custom cruise control relocation bracket
- Cold air intake
- Ruffstuff Solid engine mounts
Brakes:
- Wheeler's Off-Road stainless steel brake lines front/rear
- Tundra Brake upgrade
Lighting:
- Nomad Retrofits projector headlights
- Custom baja design squadron headlights
- Clear headlight housings
- GTR Ultra 2 LED bulbs
- Burtman Clear corners w/ LED bulbs
- APC clear tail lights W/ all LED bulbs
- Vision X light cannon 6.7 spot lights (X2)
- Baja design LP9 combo
- Baja designs XL80 lights spot/flood combo (X2)
- CBI ditch light brackets
- VLED interior dome lights, License plate light
- VLED dash/cluster bulbs
- HIDkitpros rock lights (8 total)
Interior/Electrical:
- Pioneer AVH-2550DEH headunit
- Spod Bantam system
- Extra plug in dual USB charging port/ cigarette lighters
- Cobra s75 CB with 3' firestik antenna
- CBI antenna bracket
- Garmin GPS Smartdrive 65
- Husky Floormats front/rear
- Sound dampening
- Ram mounts on driver A pillar for phones
- ARB compressor/rear/front locker switched on center console
- Blueridge molle seatback panel w/ multiple attachments (i keep my air-up equipment in)
- ARB 50 QT fridge
- Vinyl wrapped rear quarter panel windows matte black
- Mckinsey craft Co. rear drawer system/sleeping platform
- Outbound Nevada storage panels
- Rear USB/ cigarette ports with switch
- "Lemmie out" rear hatch latch
- Paper towel holer (on the sotrage panel)
- Rear hatch window switch mod
- Rear hatch "kitchen" LED's
- Custom rear hatch area ceiling light
- Front 6.5" alpine type R coaxial speakers
- rear 6.5" alpine type R coaxial speakers (custom modified to fit)
- Rockford fosgate 12 inch subwoofer/box
- Sound deadened with kilmat + soundskinz
- Ol' 1988 camry wagon heater knobs
- Custom GPS ram mount
- USB outlets installed on top of dashboard
- Maxout fire extinguisher w/ quick release
Exterior / Accessories:
- 20% Tint
- 5% ontop of 20% tint (hatch window)
- Yakima skybox 18
- Yakima spacebox 11 Sherpa equipment "matterhorn" rack version 2
- Custom traction board mounts
- Shovel w/ quickfist mounts
- Cut front and rear fenders
- Rear fenders welded back together
- Tubbed firewall
- Tubbed rear wheel well
- Raptor liner rocker panels/doors
- Windshield washer reservoir relocation
- Toytec 1'' bodylift
- Trasharoo
- ARB 2000x2500 awning
- Yakima hangover 4 bike rack
- 01-02 Clear headlights
- '99-00 grille
Armor / Recovery:
- ARB Front Bumper (bottom ribs cut off, end caps n for fitment)
- Smittybuilt X2O 10,000 winch w/ ORCISH w/8 synthetic line
- Custom built Rock sliders
- Lil’ Skip gas tank skid plate
- Budbuilt front and belly pan
- Recovery kit
- Custom tube rear bumper
- Addicted offroad tube bumper (extremely chopped)
main plans/end goals
TRD wheels/35s no body lift- - done
front/rear ARB - done
turbo setup
dual case - done
spc UCA/king coilovers - done
tokico black shocks/ new 891s -plan on different route
12" rear shocks/ dobinson/861 coils installed tokicos/LC 7.5 wraps instead. 220v's next with 12" rear shocks
AGM battery - done
d44 SAS
ford 9"/spidertrax rear end w/ 3 links
would like to do list/maintenance needs
finish blackouts setup
convert to manual speed sensors
86 entire ABS system
different coilover top mount
the first weekend i got it took a 600 mile trip to homer, alaska and went biking/exploring.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47947095953/in/dateposted-public/" title="IMG_6804"><img src="https://live.staticflickr.com/65535/47947095953_1da6a97251_k.jpg" width="2048" height="1365" alt="IMG_6804"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47947102616/in/dateposted-public/" title="IMG_6670"><img src="https://live.staticflickr.com/65535/47947102616_fed8cdffec_k.jpg" width="2048" height="1365" alt="IMG_6670"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47947106851/in/dateposted-public/" title="IMG_6727"><img src="https://live.staticflickr.com/65535/47947106851_0fffc7f9fe_k.jpg" width="2048" height="1365" alt="IMG_6727"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47947099518/in/dateposted-public/" title="IMG_6535-Edit"><img src="https://live.staticflickr.com/65535/47947099518_1a4f583d0c_k.jpg" width="2048" height="1365" alt="IMG_6535-Edit"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
i then took it on its first wheeling trip to a trail called kings river.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47947080327/in/dateposted-public/" title="IMG_7133"><img src="https://live.staticflickr.com/65535/47947080327_28d4f2c0a2_k.jpg" width="2048" height="1365" alt="IMG_7133"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47947076162/in/dateposted-public/" title="IMG_6956"><img src="https://live.staticflickr.com/65535/47947076162_f9a80f08c4_k.jpg" width="2048" height="1365" alt="IMG_6956"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47947123466/in/dateposted-public/" title="IMG_6929"><img src="https://live.staticflickr.com/65535/47947123466_a8401cd571_k.jpg" width="1152" height="2048" alt="IMG_6929"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
on a side note, im looking for a set of clear tail lights for the truck. does anyone know SOMEONE or a link to clear tail lights? i know APC's are hard to get ahold of and i have money to buy a set. im not interested in 01-02 crystal clears, euro style, or LED style. im looking for specifiaclly a set of all clears. please let me know if anyone knows something. all the links on other threads are dead or lead me to a euro style.
this is the style i'm talking about
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47947210111/in/dateposted-public/" title="CLEAR LIGHTS"><img src="https://live.staticflickr.com/65535/47947210111_58b9106f5a_b.jpg" width="699" height="699" alt="CLEAR LIGHTS"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
nice looking runner. do you have details on the last time the timing belt was changed? along with water pump?
jealous about the move to Colorado. and I have a college buddy who lives in Homer! small world.
the water pump and belt were changed at 180K. im going to order the kit here in a week or two so i dont get stranded, it has a oroblem with extended crank after being heat soaked, i think it could possibly something with timing belt as the previous owner had a reputable shop change a bunch of fuel system components. going to do and OEM kit mostlikely. homer is awesome! little to small for my taste as im in the big city of anchorage. a lot more to do here
Burtman Industries is the only place that I have seen that still offers these Burtman Industries
thank you!! ordered a set with clear corners, way too stoked. ive been digging for awhile now with nothing but dead links
well, big betsy finally came in after 2 months, ordered even before i had a 3rd gen lined up and bought.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47980400161/in/dateposted-public/" title="IMG_7144"><img src="https://live.staticflickr.com/65535/47980400161_83d81aa3de_b.jpg" width="1024" height="683" alt="IMG_7144"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
i will do a small how to but i was not into extreme detail with pictures. i will provide the links i had used to help install the bumper.
i started by taking off the bumper. there will be 2 12MM nuts to take of on both left and right fenderwells facing the front of vehicle. after taking those off, i unbolted the 4 17mm bolts connecting the tow hooks on the bottom side of the frame. after that i unbolted the 4 14mm that hold the OEM brushguard to the bumper and had help from another guy remove bumper at my shop i work at. you are left with this.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47980343208/in/dateposted-public/" title="IMG_7146"><img src="https://live.staticflickr.com/65535/47980343208_b59a26d76f_b.jpg" width="1024" height="683" alt="IMG_7146"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
you then need to cut the framehorns at the weld, and then grind smooth the weld splatter and weld itself. ive seen people remove this using a cutoff disk and grinder, a plasma cutter, and i chose to use my milwauke corded bandsaw and went right down the frame with perside accuracy. this took me maybe 3 minutes for both sides. I had used a file to smoothen everything out ensuring it would not be easy to cut my hands.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47980346787/in/dateposted-public/" title="IMG_7151"><img src="https://live.staticflickr.com/65535/47980346787_3694f05244_b.jpg" width="1024" height="683" alt="IMG_7151"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
i had fitment issues with the two front body mounts hitting the bumper support and had to cut a section off the bumper rather than grind more of the frame for better strength. I unfortunately did not capture that but it seems as if sometimes they have clearance issues and sometimes they dont, and i had to.
after making necessary fitment modifications, i bolted the frame support using the 4 17mm bolts you use to take off the bumper and tightened snugly. you then have to look on the bottom side of frame . facing up and see that there is a hole you have to drill. this hole needs to be drilled to 1/2" on each side to fit the long bolts with the sleeve. after that this is what i ended up with.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47980405451/in/dateposted-public/" title="IMG_7153"><img src="https://live.staticflickr.com/65535/47980405451_f898f3f192_b.jpg" width="1024" height="683" alt="IMG_7153"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47980358967/in/dateposted-public/" title="IMG_7155"><img src="https://live.staticflickr.com/65535/47980358967_85e29d1452_b.jpg" width="1024" height="683" alt="IMG_7155"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
on the last picture i show the gap between the support and frame. from all the videso and threads i have seen people have to fit with a hammer but mine slid in with eas and i have an 1/8th inch gap? i was thinking thats the jigs used to weld the frame could vary and so on so i rolled with it and proceeded. if anyone could shed light i would appreciate it.
you then need to put buffer kit on the bumper and in this case i have a brand new smittybuilt x20 10,000 synthetic winch and installed it to the bumper. i assembled the winch and fairlead, bolting it in via the bolts given in the winch kit and fits with ease; i have seen people with other smittybuilts have clearence issues but i had no issues for whatever reason. due to the control box wires being so short i did not want to but the box in a goofy spot, therefore i had made a custom mound by drilling holes and taking measurements to make it all even. i secured the control box wires onto the winch and tested the winch and verified proper working order. you then install the bumper via 6 medium length bolts. this is how it ended up
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47980365162/in/dateposted-public/" title="IMG_7159"><img src="https://live.staticflickr.com/65535/47980365162_e2cdc04619_b.jpg" width="1024" height="683" alt="IMG_7159"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47980369252/in/dateposted-public/" title="IMG_7158"><img src="https://live.staticflickr.com/65535/47980369252_23a651cc2d_b.jpg" width="1024" height="683" alt="IMG_7158"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47980355733/in/dateposted-public/" title="IMG_7156"><img src="https://live.staticflickr.com/65535/47980355733_9b2d5caf2a_b.jpg" width="1024" height="683" alt="IMG_7156"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
unfortuneatly i had to cut the grill in order to fit the custom box mount :( oh well it looks very clean IMO. i will get pictures later i might go wheeling tomorrow. but anyways let me know what you guys think of the writeup even though it wasnt in crazy step by step detail. these are links i had used to help installation
YouTube
YouTube
tested out both the winch and bumper today.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47990702511/in/dateposted-public/" title="IMG_7199"><img src="https://live.staticflickr.com/65535/47990702511_57fa1a8bb4_b.jpg" width="1024" height="683" alt="IMG_7199"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47990650982/in/dateposted-public/" title="IMG_7161"><img src="https://live.staticflickr.com/65535/47990650982_f94d6b2dfd_b.jpg" width="1024" height="683" alt="IMG_7161"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47990651072/in/dateposted-public/" title="IMG_3071"><img src="https://live.staticflickr.com/65535/47990651072_2b6d8ba709_b.jpg" width="1024" height="683" alt="IMG_3071"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47990651908/in/dateposted-public/" title="IMG_7181"><img src="https://live.staticflickr.com/65535/47990651908_0ec4400b3f_b.jpg" width="1024" height="683" alt="IMG_7181"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
I still like the look with the factory wheels!!! dope rig
thanks man! i plan on ordering these TRD PRO wheels soon so i can put my tundra brakes on, and regear with bigger tires when i come down to lower 48.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47991315993/in/dateposted-public/" title="trd wheels"><img src="https://live.staticflickr.com/65535/47991315993_7557645b88_b.jpg" width="800" height="600" alt="trd wheels"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
i think i want to run 34s for now so im overgeared a little? im going to be pulling a trailer and theres some pretty fat climbs on the way down. i made the trip in a different vehicle last summer from arizona
after doing the last trip there was a rock garden i couldnt get passed because i dont have sliders and i was bound to destroy my rockers/body panels. so i stole dirtcos sliders and made a near exact replica with 2/2 3/16" tubing ive already had. im not on a body lift and dont plan on doing one so i had to mound my sliders to the bottom of the frame plate and im going to weld a top gusset for added strength. this is where i'm at with them:
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48005863481/in/dateposted-public/" title="IMG_7206"><img src="https://live.staticflickr.com/65535/48005863481_8d71f170c7_b.jpg" width="1024" height="683" alt="IMG_7206"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48005863541/in/dateposted-public/" title="IMG_7209"><img src="https://live.staticflickr.com/65535/48005863541_21d51ff828_b.jpg" width="1024" height="683" alt="IMG_7209"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
i'm also really tired of not having an air compressor anymore since i sold my pickup, so i finally found a spot where i think i wouldn't compromise space with:naughty:
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48005872173/in/dateposted-public/" title="IMG_7213"><img src="https://live.staticflickr.com/65535/48005872173_038a6d1d75_b.jpg" width="1024" height="683" alt="IMG_7213"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48005950042/in/dateposted-public/" title="IMG_7216"><img src="https://live.staticflickr.com/65535/48005950042_dbe173b212_b.jpg" width="1024" height="683" alt="IMG_7216"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
i made a custom bracket but totally spaced the tank and made a use hold for weight savings in CAD. this is useless now and using just for mockup until i make the final bracket. the only thing im worried about is i think the air line going to tank will be interfering with the panel. i have to remove the cubby pocket unfortunately but im willing to take a loss in order for a gain on a clean install and using good space. let me know what you guys think.
well i finished up my rock sliders using the ideas of Dirtco's using 2x2" 3/16. this is how they turned out and im in love.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48035191131/in/dateposted-public/" title="IMG_7220"><img src="https://live.staticflickr.com/65535/48035191131_b60ff67201_b.jpg" width="1024" height="683" alt="IMG_7220"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
went wheeling to test out how they work. got to test out the new winch on a steeper section i couldnt get up that had a few gnarly ruts.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48035233953/in/dateposted-public/" title="IMG_7289"><img src="https://live.staticflickr.com/65535/48035233953_8dce2945c3_b.jpg" width="1024" height="683" alt="IMG_7289"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
finally made it to Eska Falls, Alaska.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48035190706/in/dateposted-public/" title="IMG_7340"><img src="https://live.staticflickr.com/65535/48035190706_c076193718_b.jpg" width="1024" height="683" alt="IMG_7340"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48035298027/in/dateposted-public/" title="IMG_7345"><img src="https://live.staticflickr.com/65535/48035298027_65bcceb9a2_b.jpg" width="1024" height="683" alt="IMG_7345"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
"WIDE fU***** OPEN TOYOTA"
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48035189156/in/dateposted-public/" title="IMG_7375"><img src="https://live.staticflickr.com/65535/48035189156_e2367d6afc_b.jpg" width="1024" height="683" alt="IMG_7375"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48035232323/in/dateposted-public/" title="IMG_7470"><img src="https://live.staticflickr.com/65535/48035232323_efab057b2f_b.jpg" width="1024" height="683" alt="IMG_7470"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48035289958/in/dateposted-public/" title="IMG_7379"><img src="https://live.staticflickr.com/65535/48035289958_5e3d3f297e_b.jpg" width="819" height="1024" alt="IMG_7379"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
on the way up was fairly difficult with no lockers a bunch of bogs. on the way down was steady up until i hit 2 swamps using a different trail down, and got my world rocked with hidden boulders under the mud/water. didnt get pictures as i was too busy getting winched out from my buddy with the new can-am mavrick.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48035332532/in/dateposted-public/" title="IMG_7459"><img src="https://live.staticflickr.com/65535/48035332532_3519f3af02_b.jpg" width="1024" height="683" alt="IMG_7459"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
but eventually made it to the bottom of the parking lot. i hate mud....... this will be fun cleaning.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48035231718/in/dateposted-public/" title="IMG_7484"><img src="https://live.staticflickr.com/65535/48035231718_4ea1abcb40_b.jpg" width="1024" height="683" alt="IMG_7484"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
i was tired of doing this rear main seal on a G wagon at work so i decided to pull in my truck for a bit to install my wheelers offroad brake lines from when i had ordered my poly bushings for my brand new Toyota OEM steering rack. my idiot self didn't realize there was a clip for the rear brake line and now i have to go to a store and find one. got the two front ones installed and moved on to the next task; fixing a power steering pump squeal. it squeals only on full lock so it was obvious the belt became a little loose when i last changed all the belts. I've been having this issue where i let go of the clutch and i hear a metallic loose sound and never really bothered to look into it. turned out the top bolt for the clutch bracket had came out and was sitting on the clutch pedal spring. bolted it where it needed to go and no more flex on the plate or noise. i ordered a SRQ CB antenna mount and routed all the coax and unit for my cobra 75. im tired of this a/c compressor whine so i ordered up a denso one and going to be installing with a couple other parts this Saturday. on the bright side my RMRACK/sherpa rack comes in friday!
well monday morning i heard a knock on the door and ended up being my sherpa equipment co rack! put it together and went camping this last friday. this is headed towards from anchorage alaska, to cooper lake alaska.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48124975847/in/dateposted-public/" title="IMG_7796"><img src="https://live.staticflickr.com/65535/48124975847_241bb129a3_b.jpg" width="1024" height="683" alt="IMG_7796"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48124974947/in/dateposted-public/" title="IMG_7810"><img src="https://live.staticflickr.com/65535/48124974947_9202c60958_b.jpg" width="1024" height="683" alt="IMG_7810"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48124918748/in/dateposted-public/" title="IMG_7817"><img src="https://live.staticflickr.com/65535/48124918748_03a8247f8c_b.jpg" width="819" height="1024" alt="IMG_7817"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48124975432/in/dateposted-public/" title="IMG_7829"><img src="https://live.staticflickr.com/65535/48124975432_e894680260_b.jpg" width="1024" height="683" alt="IMG_7829"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
check out all the smoke coming from a wild fire nearby! made for an unreal sunset..
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48124919203/in/dateposted-public/" title="IMG_7850"><img src="https://live.staticflickr.com/65535/48124919203_0486a0f0b8_b.jpg" width="1024" height="683" alt="IMG_7850"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
camped infront of the lake and drove 20 minutes out to go fishing at a popular river for red salmon. love my CVT setup!:biggrin2:
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48124996122/in/dateposted-public/" title="IMG_7859"><img src="https://live.staticflickr.com/65535/48124996122_0bb832b3d3_b.jpg" width="1024" height="683" alt="IMG_7859"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
came back to town and found another surprise at my door step.. ill get pictures tomorrow and show everyone! definitely the first person in alaska with these on a 3rd gen 4runner. finally finished up the CB radio setup and have yet to test it out; appearently our truckers down here dont use channel 19. trying to get rid of my complete SAS kit with a bunch of upgraded goodies all unused to i can get my front ARB and install them before i head down to the states and endure my girlfriend and i's long vacation of driving around the west coast-to colorado.
well monday...
How are the fish running this year?
I like to try and make it up to the kenai river, Russian river every couple of years. Fishing the smaller tributaries around coper landing as well because I don't like to stand arm to arm when I fish.
I always find it funny if you just take a 20 min walk you can usually fish all by yourself. I was surprised in 2017 how few fish returned compared to past years I have fished AK.
im honestly not quote sure why they upped the limit to 9/day down there from 6. they had a 50,000 fish run this year but by the time i got there they were all gone and pure combat fishing.. i caught 4 with my fly rod setup and that was it.
also forgot i had a horrendous bearing noise coming from the a/c compressor clutch. ordered a denso one(OEM) and changed it out, filled with refrigerant. all is good. also noticed i was dripping coolant and took a better look at my skid plate to realize it was canned from when i last went wheeling. took it off and the coolant REALLY starting pouring and saw that the bottom plastic had cracked. put in a denso radiator the same day and called it good. now i need a skid plate before i go wheeling. also changed my LCA,s and steering rack finally with toyota OEM. aligned it and called it good. driving a lot better and didnt realize how loose my steering was until i put in the new rack and tie rods.
Philthyphilthy
