dont want ac compressor to kick on
3bears
so after the past few days with temps at MINUS 20 or lower, it would be nice to hit the defrost but get heat.
the defrost , as most of you know, uses the ac compressor to blow dry air...but its not a hot air..its mixing hot and "Air Conditioned" air. When on mixed..( defrost and floor) it still uses compressor so not as hot.. When you switch away from defrost or mixed mode...you instantly have hot air.
Cars can defrost without the use of AC...olden days...cars with no AC.
Believe me....when you have days of minus 20 or lower...it would be nice to have real heat...but at those temps...you need air blowing on windshield
Otherwise I have to drive and constantly switch between defrost and dash heater vents to get warm
sooo….tomorrow Ill go play....but
if I pull fuse #11 in engine compartment listed as Air Conditioning System, will this eliminate the compressor from kicking on .
I don't see a fuse labeled just heater motor.
If that wont cure it....eliminate compressor kicking on....any ideas ?
coutesy of [MENTION=10169]TheDurk[/MENTION]; "Clutch relay is behind glove box, left side about knee high. It has a dark gray 2-row 10-pin pin plug". if you disconnect the relay the compressor is not going to come on. .
I'd leave the fuse alone, there's rarely just one thing on a fuse so it'll probably knock out some of your climate control as well. Agree on pulling the relay or better yet, just unplug the wire connector on the A/C unit. Done.
Don’t recall the fuse number, believe 10 amp, labeled as AC under hood. Pulling that one stops the compressor clutch. I pulled it on my 99 when the compressor started howling.
So it depends on the year and if you have the electronic or manual climate control. But on my 2000 I disabled the auto a/c with defrost. You just have to unplug an electrical connector right behind the climate control bezel. Best part is you can still push the A/C button if you need extra help defrosting. Heres a picture
This worked on my '97 SR5.
[MENTION=124615]3bears[/MENTION] If the other suggestions for the hvac controls don't work then I recommend unplugging the connector on the compressor. Can't engage the clutch without that being connected. If you're really committed you could take the ac belt off.
The compressor should not run below a certain temperature on defrost.
I can't recall what it is but I'll try and test it over the next couple of days.
-20 already???????
Same. Just did this a couple weeks ago when replacing bulbs. On mine it was a connector with two blue wires at the far right side (passenger) of the hvac control.
Now I just leave the control setting on defog/footwell whereas before I was always pissed that leaving in defrost was engaging the a/c and busting my fuel economy. I've already noticed a 0.42% increase in gas mileage.
[MENTION=139000]phattyduck[/MENTION] has a little write up on his build thread about how to do this
How is the AC compressor triggered? By the defrost button or a low temperature startup?
IMO it's a good idea to leave this alone because running the AC occasionally helps lubricate the seals and prevent failure.
This is on our 97....
We have a slider control, slide all the way to defrost and AC kicks on. Slide one spot to the left (defrost/feet) - there's an ability to be at the defrost/feet, then slide just before the AC switch is kicked on. You will still have a little air run to your feet, but majority of air runs through the windshield defroster.
I can’t really say how it get engaged but it will turn on automatically with the defrost.
You can still turn on the AC if the connector is unplugged by pushing the AC button. This mod gives more flexibility when using defrost. Also as mentioned why have the compressor on just to use more fuel if you don’t need it on?
-20 already???????
yep...bit chilly....got to minus 26 yesterday high of -13. today only supposed to get to 5 for a high
if there is a limit switch to keep it from kicking on if too cold outside....its not working.. or maybe has to get to minus 30
I like this idea...push a/c button if and when needed for extra defrost drying plus I can hit it occasionally to kick it on so it "lubricates" the compressor.
plus I have a few bulbs in that area that need replacement and have been stalling on it.
I have the dial style heater like you pictured in your post
then again....cant remember when the last time I used a/c
this looks easy enough as well.
Nice to have options
I am not certain, but if the relay is disabled I don't think the a/c button will engage the clutch. This may well disable the a/c altogether.
The simplest method is to unplug the wires that are switched by the "defog" or "defog/ feet" position of the control. On my 2000 with the basic heat this is the pair of blue wires described by Charlie and myself.
Have you looked at the A/C clutch to see if it's actually engaging?
It sounds like you have more of a blend problem.
well to be honest...no
but it sounds like it is and the engine idle goes up and down when it sounds like it kicks in. jumps from just under 700rpm to about 1100 rpm
Jhunt
