Old 01-11-2020, 10:13 PM #16
rkntoy's Avatar
rkntoy rkntoy is offline
rkntoy will become famous soon enough
rkntoy's Avatar
Originally Posted by 4Tuitous View Post
rknToy...correct, it is a base model...no ABS...but my odometer IS digital, does this not mean that the entire speedo is digital (electric)? Are we talkin' apples-to-apples here? This is the simple, straightforward fix I'm hoping for if you are right...BTW, the truck does have cruise control if that might also be a factor.
I called a Toyo dealer / shop I've had good vibes with in the past, explained the whole deal to him. He said if I could come up with a VIN from a nearly identical truck (2WD-4cyl-Auto) that came originally with the 16" stock wheels he likely could help...long shot I know but I might see if anyone on here has a truck with that original setup...Thanks for your input...
Oops - screwed up. Was thinking about an older 4runner.
Should be able to get a speedometer gear that has the right number of teeth.
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
rkntoy is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 01:24 AM #17
rallypoint_1's Avatar
rallypoint_1 rallypoint_1 is offline
Real Name: Bill
rallypoint_1 is on a distinguished road
Real Name: Bill
My 2wd V6 with 31ís would throw a code for some speedo sensor or something(canít remember) thatís behind the trans. I had 225 50 15. After the regear(4.56) no more code!! Speedo is more in the normal range now too.
1998 T4R SR5 V6 2wd Evergreen Pearl OME 880 Toytec 1/4" spacer OME 906w/OME20mm(10mmx2)spacers Bilstein 5100 BFG KO2 31's Satoshi mod 1.5" BL(Fat Pats)
My 4Runner build:
http://www.toyota-4runner.org/3rd-ge...8-sr5-2wd.html
rallypoint_1 is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 02:08 AM #18
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
I'm not 100% sure because your truck is an auto. But I do know my 97 2.7 2WD manual came with a 3.73 rear end, if that's the case for you as well one of the the cheapest and certainly the best way to fix the speedometer difference would be to drop in a good 4.10 differential.
They can be found incredibly easily here for 100$ and can be swapped out in under an hour if you know what you're doing with only regular hand tools and a tube of RTV.
Besides fixing the speedo readout, this has the added benefit of fixing the gearing being thrown off by the larger tires and putting your powerband and shift points right back where they're designed to be.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 02:11 AM #19
UnderFire's Avatar
UnderFire's Avatar
Originally Posted by rkntoy View Post
Base model - you don't have ABS and you have a manual speedometer cable. They make mechanical speedometer calibration boxes.
I've had a few base model 4Runners, they use the same electronic speed sensor as all other 4Runners in the tailshaft or the tranny or in the transfer case. All 4Runner clusters are electronic speedometers.
My single cab 97 Tacoma on the other hand did have a cable driven speedo and a cluster with no tach, I haven't checked if my nearly identical new 96 Tacoma with the tach is electronic or cable driven though.
Old 01-13-2020, 02:05 PM #20
phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold
Checked my build sheet on the Toyota Owners Spec. site...my truck is non-ABS. As per your earlier reply, do you think it possible that there might simply be a correct speed sensor for the 2WD auto trans. / 16" tire combination?
I think it is pretty unlikely that there were 16" wheel trucks built without ABS - almost all had ABS. Just to verify, check your engine bay - this is where the ABS actuator is:
You can still use the Dakota Digital interface, even without ABS, you just have to wire it in a different location. Or you can leave the speedo signal alone and put in 4:10 diff to fix it (no need for a calibrator).
'16 Honda Odyssey
Old 01-13-2020, 07:59 PM #21
owyheerat's Avatar
owyheerat owyheerat is offline
Real Name: Durwin
owyheerat is on a distinguished road
owyheerat's Avatar
Real Name: Durwin
Finally over the "15" hump!...
'99 Gen3 Base model 2WD 4cyl. Auto...
After purchasing this truck my first priority was new tires. Just a city / highway truck, no offroading. What I immediately encountered was similar to my experience with a recently restored '92 Celica Convertible...very limited choice in the original tire size of 225/75/15. Also, the 15" rims on the truck were rather shabby looking, missing two caps. I liked the look of the stock 16" rims and was fortunate to find a set at a local boneyard which I acquired and am in the process of repainting. Got a great deal on some stock size 265/70/16's from Tire Rack. Now I must deal with correcting the speedo...the larger tires as most of you will know throw it off by about 8mph on the plus side.
Yes, I have already researched this, here and elsewhere but many of the references I came across were rather old. So I'm looking for fresh input and first hand experiences...what I hope for is the most practical, most accurate, easiest to install. I have seen and read about the SpeedoHealer and Yellow Box. But if this vehicle had an option of 16" tires wouldn't there be a way to re-gear it? I would really prefer to get this accomplished without yanking the dash / kickpanels apart if possible. Really need to get going on this ASAP due to it being January...I live in Ohio...and the tires on the truck are in no way Winter worthy. Supposed to be 68 degrees tomorrow...but that sure ain't gonna last long. Very much appreciate any and all help and info for this issue...
I have a 99 base model non abs, and I jumped from stock 225's to 35's plus regeared. My speedo and odo were way off.
Official home page of the Yellow Box Speedo Recalibrator This is what I used and am very glad I did . Super easy install and easy to adjust to get speedo / odo exact. I ordered the plug and play version, and it was exactly that. I've been using it for 3 years, no issues.
Durwin
99 2.7l 5spd ARB locked F & R, 5.29's, dual cases, Shrockworks front bumper w/ Warn M8000s, King 25001-151EXT coilovers, OME 861/LC shocks, Stubb's sliders, Shrockworks full skids, custom built rear bumper, Maxxis Bighorn 255/85's, TBU
owyheerat is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 01:26 PM #22
trackntrail trackntrail is offline
trackntrail is on a distinguished road
Just get a scan gauge. You can plug in your speedo correction % and it will display the correct speed. It also lets you monitor coolant temp, trans temp (99+), voltage, etc.
2000 4Runner 4x4 Limited - TRD Gen2 Supercharger, URD 7th Injector, Doug Thorley Headers, Shrockworks Front Bumper, Bilstein shocks, Durabumps, 315/75r16 Yokohama G003 M/T
1997 4Runner 4x4 5spd - OME 883 coilovers, 891/5100 extended travel rear, 4xInnovations Sliders, SCS Ray 10s, Falken Wildpeak AT3W 285/75r16 - SOLD
Track.n.trail on Instagram
trackntrail is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 07:27 PM #23
4Tuitous's Avatar
4Tuitous 4Tuitous is offline
4Tuitous is on a distinguished road
4Tuitous's Avatar
Getting closer...maybe...
To all of you who have responded, my great thanks...
I believe I am closer to the simplest, least expensive, least hassle solution...not sure though. A recap here, with new info...
First, my vehicle: '99 Base model, 4cyl. Auto - NON-ABS - electronic speedo.
Original tires 225/75/15 - NOW riding on 265/70/16 (optional stock size).
Speedometer reading now LESS than actual speed...about 5mph @ 60mph.
Second...regarding some of the solutions offered, all of which I appreciate for your experience and time. My use for this truck is a simple daily driver...period.
I do not have nor want a GPS, do not intend to buy any additional gauge which I assume from photos has to be attached somewhere to the dash, and I have no intention of swapping diff. gears. Just want an accurate speedo...
I spent some time at a Yota dealer's shop with whom I have a good relationship. Fortunately for me, a slow day so I did get some useful info. The speedo sensor for my truck is fairly common across many T4R variants...primary part # is 83181-12020. On my truck, located on driver's side of the tranny, very easy access. The "driven gear" as they identify it is quite easy to replace, a simple retainer clip...and they usually come with a new oil seal as well. My guy at the shop had a few conversations with a tech who wasn't too busy...and after about twenty minutes, he came across a notation on one of these gears which specified "for 16" tires". Part # 33403-39415. Ah, success!...I thought...but came home to do some last verification before purchasing something I can't return. Now, not so sure, somewhat confused...
I came across a webpage called "Adventure Taco"...obviously an avid off-roader but also a serious numbers nerd...wow. What a load of info. But he did have a LOT of relevant stuff on there, including some other driven gear specs, and now this is what confuses me. All these driven gears identify as 33403-( ), with the second set of numbers designating tooth count. The 39415 variant is 33 tooth, the largest they make. But if my speedo is reading SLOWER than my actual speed...wouldn't a larger, more teeth gear make it WORSE? There are two other variations specified for auto trans., one 32 teeth and one 30. I do not know what is currently in my truck. Only way to know would be take it out and count 'em. Not going to buy anything until I get this sorted out. Still hoping this might be my easy fix...if not I'll have to go the SpeedoHealer route I guess. Hoping some of you who have commented are following this thread...anybody?
4Tuitous is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 11:28 AM #24
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck has a spectacular aura about Bad Luck has a spectacular aura about Bad Luck has a spectacular aura about
Real Name: Patrick
I'm not sure why you thought it would be the other way around. A larger than stock tire goes further per rotation compared to a stock tire.
If you are wanting to correct it with a speedo gear change you will need to know what your current tooth count is. You will want a smaller new gear (less teeth) than the current gear so that it will spin faster. The person on Adventure Taco probably regeared in addition to larger tires and needed to correct for a speedometer faster than gps speed.
2000 Limited V6 Auto E-Locker
Old 01-20-2020, 11:41 AM #25
4Tuitous's Avatar
4Tuitous's Avatar
Yep...you are correct. It's all been a bit confusing but after much research and lots of feedback I now have a better understanding. I still may end up going the Dakota Digital route but I'll at least take this path to conclusion. Seems the only way to know is to remove the speedo sensor and count gear teeth. Just curious...since I know absolutely zero about the internal workings of automatic transmissions...do you have any knowledge about how the drive / driven gear for the speedo sensor engage? Concerned that a smaller, fewer tooth driven gear on the sensor might not properly connect with the drive gear. Was wondering if perhaps they only engage when tranny is placed in "D". Appreciate your response...
Old 01-20-2020, 01:32 PM #26
Iffykid Iffykid is offline
Iffykid is on a distinguished road
I would start by getting a GPS reading compared to the speedo and go from there.
Re
On my stock 00 Limited I replaced the stock 265/70/16s with 265/75/16s assuming my speedo was going to be off but not knowing by how much I just checked and my speedo was basically right on the money at 60-65 so evidently my stock speedo was reading faster than actual, My understanding it is quite common for a stock setup to read faster than actual mph on alot of older vehicles.
Iffykid is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 02:50 PM #27
Swapping the diff is probably the cheapest option if you can do it yourself. You can probably find a free one on here! You'll need to know what your current diff ratio is to know if it truly is going to be cheap though - only the 4.10 gears are cheap (I know what your diff ratio would be if you had the V6 - not sure with the 4 cylinder).
Otherwise, just pop that sensor out and count the teeth and report back.
'16 Honda Odyssey
deal , size , tire , tires , truck
Edited: Price correction: 2013 Limited (20") wheels and OEM tires (5) Denver mwol For Sale: Suspension/Wheels/Tires 2 07-09-2013 08:30 PM
Tires and Speedo buzzie0013 Classic T4Rs 17 10-15-2011 08:17 PM
Larger Tires bigwalts4runner 4th Gen T4Rs 7 07-05-2010 12:15 AM
Bigger tires - Spedometer Correction zon 4th Gen T4Rs 11 06-11-2009 01:34 PM
larger tires and speedo correction... huckleberry668 Engines / Suspension / Wheels / Tires / Audio / Accessories 3 08-30-2007 12:33 PM
