AC blower turns on at "ON" key position?
2000 4Runner Limited
Just a while ago, when i turned the key to "ON", the ac blower turned on (low speed) but the AC controller was in off. when i cranked the engine, the blower kept running. I pushed the AC off switch but the blower won't turn off. I switched off the engine and tried again, the blower turned on with the key still in the "ON" position. repeated the process an third time with the same result.
It just happened today. Earlier, I sprayed Lysol in the cargo, rear passenger and front, including the blower area. before spraying, I turned on the engine then the AC. The blower turned on only when I pressed the AUTO button.
What are your thoughts on this?
