Fuel Filter on 2.7 4cyl
tofarout
So who @ Toyota thought it was a good idea to put the fuel filter on the 4 cyl engine UNDER the intake manifold?
So I have had my 98 4Runner for about 3 weeks now and got the new filter to put on and crawled under to replace it. I looked and looked, tracked the lines from the tank forward. I was stumped, why is the filter not under here like every other vehicle in the WORLD? :) Finally found it under the intake manifold but can't see any easy way to replace it without taking off the whole manifold.
Anyone else with the 4 banger ran into this and has experience replacing it with the manifold on?
Thanks!
I was able to get to mine with a socket set and some persistence. Didn't have to remove the tire. It was a bit of a pain though.
Okay, I feel like I'm on Candid Camera. I can't find the fuel filter anywhere on my 2.7l I've looked behind, under, on top of manifold, all along drivers side wheel etc. Does anyone have a photo they can upload?
replacement of the Fuel Filter on a 1998 4runner 2.7L
read a lot, but no one actually put all the steps or at least tips about how to replace the fuel filter for the 2.7l engine, which is a big task if you are not ready or never done it yourself, a repair shop was going to charge me 150.00 to have it replace but decided to do it myself, it took me 3hrs to do it, but I did it and save me money, no leaks, works just fine, I'll post pictures and tips that I think will make it easy for someone else out there, is it the reason of this blogs to find help and people giving hints to help others, and of couse to save money in the process and learn to know your vehicle, thanks....
toy.jpg the A is mark, there will be a hole, where if you have a long extension, could get to the screw on top of the bracket holding the filter, its the easiest way, the B is just marking where you will find the fuel filter, check the other pics
toy1.JPGthis is the access hole from previous A marker
toy2.JPGhere is a pic of the filter, with a mark of the screw that is holding the filter to the bracket, now be very careful and try to keep an eye on the mark on the screw to set it up to the same distance on the holes, otherwise will end up removing the filter until you get it right.
toy3.JPGhere is a clear pic of the filter, you'll need a 17mm to remove the fuel line screw, also you can see the backet and the screw holding the bracket on the bottom..
toy4.JPGhere is the view from the driver side front tire, but I have no need to removed the tire, was able to the to the bottom screw from the inside..and if my mind works, I think the screw is a 12mm, not sure/sorry
toy5.JPGnow this is one fuel line was the hardest for me, since you have no view of it or clear access to it, but the way that it work easy for me was by moving what I believe its a heater hose, from the top and it gave me a clear feeling(touching) where the screw was and was able to get it with a wrench.
toy6.JPGand this is the last pic to give you, I want to say to help anybody when installing the new fuel filter, thru hole B and hole C gives you access to put or hold the screw in place til gets to the hole so you don't end up dropping and looking for it for a few minutes, again its just to help, I'm not a mechanic and nor an expert on it, but I hope by looking at these pics and hearing different ideas can give some one the understanding on what to expect, just keep an eye on those screws and good luck, and keep a bowl or towl ready for some gas leaking out or the lines, good day...
It can be done.
It can be done without too much hassle if you are so inclined. Takes 1-2 hours the first time, faster the second I'd guess. Not as bad as it looks.
Can all be done from the top of the engine bay. Only had to move a hose or two to get arms down there. Maybe it was a wire, not much anyway. Worst part is, you are working nearly blind 'cause of the location under the manifold. Get the wife's hand mirror down there so you can see what you are working with. I propped a flashlight down there somewhere too to light it up.
Longest part of the job was sorting out what tools would fit. I used a short wrench for one, and a long wrench for the other banjo bolt. A socket with a short extension for one, and a long one for the other mounting bolt. I think a universal flexer too.
I used an OEM filter and had no leaking issues. Good job to figure out at home so you can repeat it on the side of the road if you ever need to.
I agree, a stupid location. Anyone figured out how to put it somewhere else??
I did this on my rig when I first got her. Looked everywhere like every one but eventually found it. just take off the driver side tire as it will give you plenty of room to get to the filter. it is a rather easy job once you take off the tire. it can be done from up top but much easier this way. it took me about an hour once I found it.
I recently changed mine. I took off drivers side wheel and it took about an hour. And I'm not the fastest or best mechanic out there. It's a pain, but not nearly as painful as paying a mechanic.
I wish they would have put it on the frame rail, like all the V-6 models.
Durwin
The same guy that thought it was a good idea to do the same thing on the 22RE.
I moved mine to the fender, and I recommend it. I expect the fuel lines on the 3RZ are long enough to do the same thing.
Any pics of your setup? Would like to see it. Changed my fuel filter today, which is probably the original from 1999. Not too hard, but a different location would be nice.
I bought a filter for my tacoma 2.7 when I first got it. Looked around and finally found the filter, read a bunch of installation articles and decided that toyota was absolutely correct. It truly is a lifetime filter. I still have that filter laying around downstairs somewhere, truck is still running great years later.
what size are the filter housing fittings
anyone know the size of the fitting on the filter housing? not the banjo bolt itself, but the piece right behind the banjo bolts.
2.7L Witchcraft
STRAIGHT UP F*** whoever decided to put that cheap ass fuel filter under the intake manifold where it's that much of a pain to get to, if I ever come face to face with you we will fight I promise
seltzernator
