Old 08-22-2023, 01:10 PM #16
4-FUN-R 4-FUN-R is offline
4-FUN-R is on a distinguished road
OP here. I'm going to see if I can recover the rear hatch wiring from the damaged door (if they still have it in the junk pile) of my 2001 SR5. I'm not sure of the year on the door we installed but I may be able to find out from the body shop buyer, or maybe a S/N or something. All this sounds daunting to sort out!!
4-FUN-R: Chris
'01 SR5 2WD 250Kmi 3rd Owner DD
Handy with Service, Noob to Upgrades.
Recent: Reg Maint type service, fighting leaky rear shaft seal and tranny solenoid error codes.
Goal: Another 100K miles!
4-FUN-R is offline   Reply With QuoteReply With Quote
Old 08-22-2023, 05:05 PM #17
Originally Posted by RodrickHeffley View Post
Worst case scenario, I can use the RS3000 remote with its strange dual-system buttons between two separate RS3000 systems in my 4runner, one system can be the OEM security, tied to one button on the remote, and I can make the other button roll down and up the window with a separate system.
Time will tell, I really just need to find a few security boxes to tinker with at a junkyard.
My understanding is that the '96-'98 never had the ability to roll down the rear window remotely. I'd be happy to be corrected by a '96-'97 owner. I only used a '97 SR5 as a parts truck (but have pulled an RS3000 out of it - yes, it is an ugly mess of wires).
The '99-'02 only has the ability to remotely roll the rear window DOWN, not up. To roll it up, you have to use the key in the rear hatch or the dash button.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-22-2023, 08:41 PM #18
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
None of mine except one have a working keyless entry...:/
Old 08-22-2023, 09:48 PM #19
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
yeah you're correct about them not being able to roll down remotely, that's what I'm looking to add to my 98, using either another RS3000, RS3200, or something else one way or the other, it's just going to be a lot of wiring that I need to research first
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 08-22-2023, 11:02 PM #20
Update: I took the rear door (hatch) apart and confirmed it has the orange box ECU unit and all the wires in the assembly look in great condition. The body shop manager did indeed scrap the old door. However, he says they always pull and replace the electronics and wiring of the original units unless they are too damaged during the incident. The new door from LKQ Parts was a '00 SR5 model he thinks, but is checking. So all the wire harnesses and plugs matched. The wire harness of replacement door at hinge area was cut coming from LKQ, so that sort of confirmed he indeed swapped the wiring. All the wiring including the hinge area was in great condition with black tape mostly intact everywhere. Attached is a photo of the ECU unit and P/N checks out for '01 compatibility. So the question is, like someone asked here, is this unit also the remote receiver for door lock/unlock? Also note, I confirm all functions of door lock/unlock, window up/down with dash switch, window up/down with key, wiper, operate as they should. Just not any remote function. I tried to reprogram myself via youtube instruction, and I hired a keyless remote tech to also try to reprogram. there was never any beep or flash to indicate anything was communicating during the reprogramming. Also, I have the "beeper" in the front passenger fender by the hinge. What's next?
And apparently I need to figure out how to add a photo here
4-FUN-R: Chris
Old 08-23-2023, 02:06 PM #21
It is WAY more than you think to do it OEM style. Like, buy a '99+ and body swap it complicated. Well, the chassis is (pretty much) the same, but nearly all of the wiring related to the interior of the 4Runner changed between 98 and 99.
An aftermarket alarm with a window rolling module would be a better bet, but still not a slam dunk.
Old 09-30-2023, 12:40 PM #22
Tunnelrat5 Tunnelrat5 is offline
Tunnelrat5 is on a distinguished road
Bought used T4R without key fob, how do you get replacement?
Tunnelrat5 is offline   Reply With QuoteReply With Quote
Old 12-28-2023, 12:38 PM #23
Malamute Malamute is offline
Malamute is on a distinguished road
Ive used these guys a couple times, the parts seem good quality (the claim OEM parts) and very reasonably priced, and they have programming instructions on their site. Theres also youtubes describing how to program them. Its pretty simple.
Replacement Key Fobs From Keyless Entry Remote Inc - Shop and Order Online
Malamute is offline   Reply With QuoteReply With Quote
1/4 , keyless , rear , remote , work
2003 4Runner Factory Remote Keyless Entry Remote or Fob - $25 - Dallas, TX Spktyr For Sale: T4R Items 8 11-05-2019 02:03 PM
'97 4R: Keyless entry remote & alarm remote iaonbb 3rd gen T4Rs 6 03-01-2016 11:42 AM
Keyless remote / keyless entry reprogramming question(s) Kimm 3rd gen T4Rs 8 11-25-2013 08:51 PM
Keyless entry piezo location dr_optical 4th Gen T4Rs 2 01-18-2011 11:43 PM
Keyless remote / keyless entry reprogramming question(s) Kimm 3rd gen T4Rs 2 04-25-2010 12:42 PM
