engage into lo4?
shootmymime
i have gone in to hi 4 alot... but it seems like when i go into lo 4 i allways grind gears.... i have gone into it once or twice but allways forget.... how do u do it exactly?
Mine is a Limited so I have the shift on the fly but I think engaging 4LOW is the same. Stop, shift into neutral, wait a few secs and then engage 4LOW. If I stop pop it in neutral and don't wait a few secs, mine will grind just a bit when engaging.
Yeah, as stated above, stop and shift into neutral, then 4lo. That is on an auto of course. On my manual I simply would stop and engage the clutch, the same thing more or less I suppose. With the 5 speed Toyota states that you can shift into 4lo by depressing the clutch and going less then 5mph. Anytime I tried to go into 4lo while moving at all it would grind, so I always just stopped. On my 02 I stop hit neutral, push it into 4 lo then drive, it has never ground for me doing this. I had never owned an auto, had 4 5speed Toy 4x4's, first time I went to 4lo in the 02 I left it in D and stopped, I had to push the lever pretty hard but it did finally pop into 4lo. Then I took out the manual and read it, after trying the proper technique I realized this was the better way.
ok cool, ill try it and see what i get, might check the pwners mannual to see what it says
and yes it is an auto
i have a 2000 limited 2wd, and have tried to shift into 2wd before, and other than 4HI, it grinds. when you say to stop, shift it into neutral and then engage into 4LO, do you mean to shift the primary transfer case into N, or the 4WD transfer case into N?
also, i have looked at other t4r with 4WD, and i havent seen one that looks like mine. on my 4WD shifter, it has 2HI/4HI, 4HI/L, N, and 4LO. and it goes in a U shape. every other one i have seen doesnt have the 4HI/L..and also just goes in a straight line. what is yours like?
Yes he means the primary transfer case. And the shifter that goes in a straight line is the electronical type of 4wd with a button. The type you have you shift manually.
The Limiteds have push button for 4HI. There is a button on the side of the transfer case selector and it says 4WD. When I say stop and shift into neutral i mean shift the transmission into neutral then wait a few seconds before pusing the selector up into 4LOW.
what do you mean the ones with the button have to be shifted manually? I can go into 4HI at speeds of 60mph and below.
ok... with some confusing answers i just went out and messed with it for a few min...
1. while driving slowly engage HI4
2. STOP, (while foot on break shift tranny into N)
3. manually move Xcase lever to N
4. put tranny into park
5.whait a few seconds.
well for me i do or else the engine keeps some geers turning and it would grind.... but i will try it on my way to school
wow, thanks guys. this really helps me out. im going to try to shift into 4LO this weekend when i have time. also, does anyone know when toyota started making the electronicly shifting 4WD, the one that shifts in a straight line? and also, when i shift into 4LO, is it true that i have to be driving in a straight line? and does it have to be while i am driving forward? because sometimes my 4HI wont engage, and so i drive in reverse for a little bit and then forward again, and it engages just fine. thanks in advance guys.
If your 4HI won't engage, just rev up the engine a bit while turning the steering wheel lock to lock. The system is run on vaccuum, so revving the engine helps.
Also, I don't know what you mean by driving in a straight line? You shouldn't be moving if you're switching to 4LO. And when you're in 4LO, you shouldn't be on pavement--only off-road/snow/mud. But in 4HI, you can engage that anywhere (since you've got an AWD system).
Also, everyone should RTFM. :bigok:
I don't have an AWD so I have to be in a straight line if I am not on a slick surface. However to keep things lubed I do engage 4HI on the highway once in a while when it is raining.
i do the same thing when it rains! haha, and here i am thinking i was the only one.
I also used to do that in my old 98 and ended up busting the transfer case seal. So keep your eye on that.
so what is the 4HI/LO that i have on my shifter. i understand what 4HI is and i understand what 4LO is, but what is 4HI/LO? does anyone else have this on their 4WD shifter?
AndiGarage
