Trying to decide what lift you to go with here. I have been studying the forums, yotatech.com and toyota-4runner.org, trying to see photos and get advice as to which lift to get and i am still a little confused. I have a 1999 toyota 4runner limited 4x4. it has 60,000 miles and all the suspension components are original. the truck is a daily driver and my only vehicle. i dont offroad, but i do tow a trailer with atvs, and my stock suspension squats like crazy. so im looking for a 3 inch lift that is going to be a good set up for a daily driver and weekend towing of atvs. i want to upgrade to 285/75/16 tires with a steel rockcrawler wheel, most likely with a 4inch back spacing. i was looking at the RUN3-DR (3inch front spacer lift, with ome 3 inch coil and front dif drop kit) and the OME3-RUN (ome front spring with top out spacer, and 3 inch ome rear spring ). which of the two do you recommend, and do you recomend the dif drop kit and the panhard bar bracket and new shocks? i also heard on the forums that since i have 1999 4runner that the stock coils are 1inch longer then most 3rd gen 4runner models, so will that affect how the truck sits if i use the spacer kit. also how stiff are the rear springs, i want to keep the squating to a limit when i tow.
