Painting rims
96Blacklimited
Alright, I am trying to complete my paint job on my rims (Sequoia rims). They were a little corroded, but i did exilent prep work an primer job. I am painting them black but not sure what KINNA paint to use. I want them to have a glossy look but paint has to be durable any suggestions.
Also i painted my calipers w/VHT caliper paint(VHT SP734 Gloss Black Brake Caliper Paint Can), Can u use this same paint to paint my rims?
dude to avoid any problems, get them powder coated... u will realize that this is the best thing to do... if u spray can them u will find in a little while they will have problems... just warning u now.
Thanks dude, but my truck is a poor man budget, which mean i plan on doing most of the work by myself. I already painted my rotors and drums black and cured them in an oven, Been 10month now and they are still looking great. I plan on doing the same for my rims. I know once its cured it can last for years. Plus i rather put my money in a Lift Kit and nothing cheap i wanna spend around $400-$500 for a 3'' kit any suggestions?
use engine enamel
and click the link in my sig, it's got a step-by-step on how i did mine
Thanks dude. Engine enamel it is. Did you bake your rims after you painted them? What kinna clear coat did you use. My rims are already primed so i ready to paint. Getting a new camera and hope everything will be done in order too post some pics.
He told me he baked them, before and/or after.
I just baked them a little before spraying so the metal was warm...then I baked after every other coat
I just used Rustoleum flat black because I off road a lot and know my truck isn't going to win any beauty pageants anyways. I used no primer, just cleaned the rims with acetone and soapy water and sprayed 2 coats.
I realize you want yours to look nice and pro so don't take this as advice, I just thought I would add that after 6 months, my crappy paint job is actually holding up quite good. If it starts to chip or whatever, I'll just hit them with the rattle can again. I am thinking of buying some wheels from:
http://www.wheelersoffroad.com/4runnerwheels.htm
just because they're cheap and I have another set of spring/summer/fall tires to mount soon.
