mixing daystar front lift with rear lift spring???
hdoggie24
so after reading about the newer daystar front lift(that have stud extensions so no need to disassemble strut). i wanna go with this but dont want to use rear spacers. looking for way to lift rear to make it sit level with daystar lift. also like poly spacers cause heard they are quieter. i think for front daystar has 1.5" and 2.5" sizes available??? im running 31x10.5 15s, not planning to upgrade for awhile. 2wd driven 100% street its daily family car so want to drive smooth(not firm like i heard ome would be if i did ome all around). did research but couldn't find much regarding newer daystar spacers. would ome906 with daystar ride nice on street and sit level? since 906s are the less firmest of the springs. any help would be great. anybody use the new daystars yet??
i went with the 1.5" front daystar spacers and the '99 tall rear coils. haven't installed them yet but have them sitting in garage. turns out they don't make the easy install kit for our 4runners so yes the front strut will have to be disassembled to install spacer. i only went with 1.5" as its top mount so it won't preload the spring. also im only running 31s so don't want my tires too look to small with a 2.5" lift. hope that helps good luck
