How hard to pull center console apart?
Muti007
I'm going to b installing my new stereo today and would like to run the iPod cable into the center armrest as I have on my other cars. How hard is it to pull that all apart to run the wire into there? Any help would be appreciated.
It's not hard to remove all those panels, but you can't wire the cable in there without drilling a hole for it, I already tried.
when i installed my alpine radio i ran the ipod wire into the glove box but when my runner got broken into it was obvious when they opened the glove box so i got another ipod and now it sides under the panel where the shifter is so its hidden and good luck if they can find it... just thought id share that bc if u put it in the arm rest just make sure to make the wire stealthy!
Thanks for the help guys.
This is one of the reasons I always wire my cars this way, the glove box is where people expect it to be. It's also alot more convenient in the center armrest and easier to reach. And I was planning to drill a hole forthright cable, I've done this in the past.
Ya i thought bout doing this a while back bc i saw someone had done this on YT but i figured since i got broken into once i would make it almost impossible to find unless u tore apart my runner.
Center Console
It's super easier to remove the console and run the wire. Just look at this thread and the threads that are linked in it and you'll see everything you could have ever wanted to know about the center console. The seventh post down shows my iPod cable heading to the console.
x2
Just put in a new stereo a couple days ago, super easy to get the center console apart but there's no way to get the cable into the armrest compartment without drilling. Another thing I discovered was that it's really easy to remove pieces if you rotate them 90 degrees to clear the climate control trim panel and the shifter knob.
Just got done the install. I'm beat and a little frustrated. Details tomorrow, overall I did a good job tho.
The console is very easy to dissasemble, its 2 screws and 2 bolts, the screws are on the sides of the console right about at the shifter assembly, and the bolts are in the center console. If you have Rear heat just make sure you unplug the wire when you are pulling the console off. The Center console is way easier than taking the dash off. PM if you run into any issues, i have had both off many a times. My "99 console swap" link in my sig can help you too with some pics.
I see you've already got it done, but anyway here is a photo of the hole I drilled in my armrest console to run the iPod wire through.
I much prefer this to the glove box method. All controls for my HU are done through the screen itself, you never have to touch the actual iPod.
