Old 05-11-2011, 08:33 PM #1
Lugnutz's Avatar
Lugnutz Lugnutz is offline
Lugnutz is on a distinguished road
Lugnutz's Avatar
How to install a Clock Spring a.k.a. Spiral Cable.
If the clock spring in your steering column is damaged, your horn, cruise control, or airbag (or all 3 may not function). Here is how I made the repair.
Special thanks goes to T4R member Singtoe (you rock man!) for helping diagnose the problem and getting me the parts I need!
I like photos, so that's how I post DIY stuff. So I had to finish the post by replying to my own post! LOL!
I hope you like it anyway.
Lugnutz is offline   Reply With QuoteReply With Quote
Old 05-11-2011, 08:35 PM #2
Lugnutz's Avatar
Lugnutz's Avatar
That's all for now!
Old 05-11-2011, 10:53 PM #3
kball's Avatar
kball kball is offline
kball is on a distinguished road
kball's Avatar
Nice write up man! I love pics!
1996 SR5 4Runner V6 4WD Auto
Toytec Ultimate w/ OME 890's plus 1.5" daystar spacer
60028 OME shocks, Goodyear Duratracs 265/75 -16
B&M 70268 with Magnefine filter, 199mm TBU
236K miles
kball is offline   Reply With QuoteReply With Quote
Old 05-12-2011, 04:34 PM #4
Lugnutz's Avatar
Lugnutz's Avatar
Thanks KBall. The clock spring I installed came from a 1996 T4R. The only difference from my 1998 was the clip for the airbag. I simply cut wires and spliced on the 98 clip that I had from my broken clock spring. It pays not to throw stuff away!!!!! LOL!!!! See Pix. The 96 clip is on the left.
Old 06-11-2011, 03:33 PM #5
shootis shootis is offline
shootis is on a distinguished road
clock spring question
I'm pretty sure that my clock spring is bad but just wanted to make sure.
On the 4 pin connector that is located just to the left of the word top, the 2 right pins show continuity. I think the cable is shorted internally.
Can anyone confirm that all 4 pins should not show zero ohms?
Thanks!!!
shootis is offline   Reply With QuoteReply With Quote
Old 06-11-2011, 06:38 PM #6
GottaBeTRD's Avatar
GottaBeTRD GottaBeTRD is offline
GottaBeTRD is on a distinguished road
GottaBeTRD's Avatar
I was directed to this thread. i recently have inherited a brand new clock spring if any one is interested. Ill be putting it on ebay in the next couple of days. i have an add in the classifieds section but i had no clue what this thing was so i called it an airbag sub assembly
01 SR5 SPORT
Many mods done, Many more to come
Build Thread
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
GottaBeTRD is offline   Reply With QuoteReply With Quote
Old 06-11-2011, 06:45 PM #7
If you can confirm that mine is bad I'd be interested in your clock spring.
Could you take a minute and ohm yours out?
Thanks!!
Old 06-11-2011, 07:30 PM #8
GottaBeTRD's Avatar
GottaBeTRD's Avatar
i dont have an ohm meter im ausuming thats what your refereing to? is there a way to do this with it unplugged and everyhing?
01 SR5 SPORT
Build Thread
Old 06-11-2011, 08:52 PM #9
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a name known to all TheDurk is a name known to all TheDurk is a name known to all TheDurk is a name known to all TheDurk is a name known to all TheDurk is a name known to all
TheDurk's Avatar
Very nice write-up. You might add the following:
Steering Wheel Nut: 37 ft-lb.
Torx screws on side: 78 in.-lbs.
My Backyard Frame Swap
Old 06-15-2013, 05:50 PM #10
MR.H MR.H is offline
MR.H is on a distinguished road
Great diy! easy fix and now i can be lazy with cruise control
MR.H is offline   Reply With QuoteReply With Quote
Old 08-07-2013, 11:44 PM #11
genec's Avatar
genec genec is offline
genec is on a distinguished road
genec's Avatar
Anyone have this saved off some place? .
Seems photobucket is asking for an upgrade for more bandwidth so not pix are displaying. i saw them earlier today and had problems saving and now they are gone.
Fantatastic DIY is right, Lugnutz. I would not have thought about attempting the repair if it were not for your instructions.
Thank you.
genec is offline   Reply With QuoteReply With Quote
Old 08-08-2013, 01:38 PM #12
thor999 thor999 is offline
thor999 is on a distinguished road
Thank you.
Same here... i would actually consider this preventative maintenance!
thor999 is offline   Reply With QuoteReply With Quote
Old 09-04-2013, 04:41 PM #13
genec's Avatar
genec's Avatar
Thank you.
Fantastic! I finally got around to doing this and the instructions were right on! Thanks for your help in getting the pix again. took about 30 mins.
Old 12-30-2013, 05:19 PM #14
bike bike is offline
bike is on a distinguished road
So my 97 has a broken spiral cable. Took it apart, and fixing it doesn't seem to be worth it (broken right near the connector. Ground back the plastic to expose the copper leads, but soldering it doesn't leave much tolerance and I'd rather not eat my airbag for the savings.) Anyone know what years/models will work if I go hunting at scrap yards?
97 4Runner - SR5 - 5spd - Factory E-locker - 285/75R16 Duratracs - Allpro Upper Control Arms - Allpro Coilovers - LC Coils - CBI Rear Bumper
bike is offline   Reply With QuoteReply With Quote
Old 12-30-2013, 05:37 PM #15
zacattack20's Avatar
zacattack20 zacattack20 is offline
zacattack20 will become famous soon enough
'96 and '97. it has to have your two spoke style steering wheel for it to work.
the newer style steering wheels have a different airbag connector.
'98 SR5 Converted to '01-'02 Sport Edition
Matte Blue Vinyl Wrap - Black Interior - Too Many Mods
Build Thread
Instagram: 98trd4r
zacattack20 is offline   Reply With QuoteReply With Quote
clock spring , spiral cable
clock spring? 152 Sumo 3rd gen T4Rs 4 05-03-2011 11:17 AM
FS: Clock spring, turn signal, head light, horn switch for 3rd generation Singtoe Classifieds - buy & sell (no commercial ads please) 1 04-29-2011 02:54 PM
Wanted 96 4Runner clock spring / spiral cable enertronik Classifieds - buy & sell (no commercial ads please) 2 02-13-2011 04:33 PM
'99 - Dash/clock not lighting up after headunit install reubenc Engines / Suspension / Wheels / Tires / Audio / Accessories 2 09-19-2009 09:38 PM
Clock not working after install philo Engines / Suspension / Wheels / Tires / Audio / Accessories 2 05-25-2007 02:08 AM
