Reuse gaskets?
Nine7yota
Hello. Short recap.... Blowin white smoke at start up on my 3.4.. Pulled the heads found a small coolant pond on #3. Send the heads out, installed and fired up. Drove for 30 miles and started her back up after 3 hours. White smoke again.:redbrick: ANYWAY.... Can I reuse my intake and exhaust manifold gaskets? Hate to see factory pieces go to waste. Thanks
Intake yes, not sure about exhaust. Make sure there isn't something that is causing the intake manifold gaskets to not get a good seal. Had the same problem once before when changing a knock sensor and was getting a ton of coolant in one of the cylinders. Hope it's not your head gaskets again.
DJNutshell
