ac and stereo question
horsey
I have less than 1500 miles on my car and when I have my AC on at 72 degrees, its seems like 78-80 degrees. I also have the recirculated button on.
Do anyone experience the stereo being softer when the car is in motion? The volume is set around 15-20... Thanks!
Are these trick questions? :biggrin2:
You have to give the AC time to reach your set temp. You will know when the fan speed changes to slow. You could use a thermometer to see how close the temp. really is and adjust accordingly. I find that with the recalculating button lit the AC works very effective at cooling down in a timely manner. With the light off it's shit.
As far as the radio, I find the more volume you add the better the sound quality/definition.
Koz
hmmm
the_josh said:
72 is chilly? wow thats like way hot to me!
mine is always at 64
you're right, but during extended trips, it's usually at 'low' and then i get real cold and i raise the temp. and usually it'll end up at 72/73, even if it's 90
Since we are talking about A/C, has anyone noticed that at times the A/C seems to get warmer when the vehicle slows down. This doesn't always happen and I was thinking that it might be due the the RPMs. At times it stays warm for only a couple of seconds and at other times it seems to stay warm for around a minute or so. I keep my temp at 70 degrees. I don't use the auto feature either.
i've noticed it too, but it seems to do that at temps. at 70 or so. i don't use my auto feature either, cuz the fan speed NEVER goes down even after 10min or so and i'm frozen.
Thanks KOZ and 00void for getting back to my response. It wasn't that hard for you to answer, Koz, right?:p Anyways, hey 808Sport, are you experiencing the same? When I'm driving for a good 15 mintues with the temperature set at 72 it is really comfortable, but all of a sudden warm air starts to blow in from the vents. I don't know what would cause it because I'm going at the same speed and the recirculate button is on.. This hot air continues to blow for a few minutes. Once I set the temperature below 70, it starts to get cold again.
Once again, thanks guys for the replies...especially Koz...:D
horsey I have the exact same problem. what do you think it could be? it doesn't always happen though. I am trying to figure out when it happens. can you tell approx when it happens? mine seems to be in the morning.
A/C, etc.
I also find the A/C in my '05 4Runner to be kind of weird. Sure, it works fine......but whoever designed the buttons and knobs on it should take a long walk off a short pier. I never use the "auto" feature and usually just leave the darn thing on "low" all the time. While it gets cool enough inside - even when it is 90+ outside, the system is too cryptic to mess with it.
Maybe I am "old school" in that regard, but I would favor simpler, manual controls. I prefer an analog slide or dial instead of the numbered temperature readout that may use a thermostat somewhere with a temp that is different than what is blowing at your face.
Toyota should have spent the money on separate temp HVAC controls for the driver and front passenger. Anyone who has a wife or a girlfriend knows exactly what I mean. They complain because it is "too cold" in the cabin during the summer and they'll want their feet to roast in the winter months. Ah, women!
:o
Other than that, I really, really love my 4Runner and totally enjoy driving it.
I have mine set at 68 (auto) with the recalculating button lit. This seems to be the comfort zone for me, but I like it a little cooler then most. After you find that zone, the controls will grow on you. You have to use the auto mode or you will be fiddling with the controls all the time.
As far as the temp going down at low RPM, yes, all AC systems will be more effective at higher RPMs. Also the compressor does not run continuous, it cycles on and off. This is why sometimes when idling you may feel the drive train pulse. The RPM are raised when the compressor clutch kicks in. Some systems will disengage the compressor when you put a heavy load on the motor. The AC takes a certain amount of power just to run; this is why it affects your gas mileage.
Koz
Jeff: I hear ya man. My wife is always in sandals and shorts while I am always in sneakers & jeans. Duel climate control is something that I really miss.
Koz: 68 frickin degrees!! I have yet to use the "Low" setting.
The dual zone was a must for me; the wife has her side set at 72.
Koz
It depends...sometimes it happens in the morning and sometimes at night. I will bring it into the dealer when it gets worst. I'll keep you posted when something happens.. Thanks!
808Sport said:
Anyone else have this problem? Maybe its just Hawaii Runners?
I haven't really noticed this, though the perception of temperature can vary greatly from person to person.
When I drive to work in the morning (over the Pali), I usually have my AC off and recirc off and it's comfortable for me.
When I drive home in the late afternoon, I turn the AC on to "auto" and set the temperature to 67 (or LO) to quickly cool it down. Halfway home (again over the Pali), I usually turn the temp up to 71 or else it becomes too cold.
I think I've only manually adjusted the fan setting once or twice; otherwise, setting the temp and leaving everything else to "auto" works fine for me.
When the car is in motion, the stereo is contending with engine, road, and wind noise, so I would expect the volume to seem softer compared to standing still.
My JBL is usually set around 21 - 25. If I'm listening to a CD, depending on the volume level of the CD, I may raise it to 31 - 35.
I really like the steering-wheel controls for the radio, as I'm able to dynamically adjust the volume with very little effort as I drive.
2001ATL
