Old 10-03-2013, 01:56 AM #1
kevinpt's Avatar
kevinpt kevinpt is offline
kevinpt will become famous soon enough
kevinpt's Avatar
How to: A/C in console
so a few months ago i got the idea i wanted a way to keep drinks cold when going on trips. so i got to thinking of ways i could buy or make something that was cheap but worked and this is what i came up with.
closed
open
back side
things you need a PVC bushing, a drain plug, and a whole saw
Step one: remove console from truck
Step two: disassemble console so you have just the main compartment tub and A/C vent
Step three: separate tub and A/C duct
Step four: locate the location your going to drill the whole in the console tun
Step five: cut hole in console with whole saw
Step six: remove whole saw from main drill bit
Step seven: reassemble console tub to A/C duct
Step eight: take whole saw without main drill bit and insert into the hole and cut into A/C duct by hand
Step nine: clean up holes drilled and insert pvc bushing
Step ten: cut pvc bushing to desired length( i took the drain plug and inserted it into the bushing and put it all in a drill press and cut with metal lathe tool to make chamfer
Step eleven: put everything back together
Step twelve: if you want you can insulate the console or add Styrofoam divider to console
when all done you can close all A/C vents and open the one in the console and keep your drinks cold
Budget Build,5100's with tacoma/fj coils, CBI Offroad Front mount hitch,MY MAP LIGHT MOD How to: A/C in console
09 limited Titanium Metallic ,stock, color matched emblems, LED interior lights, winjet fog lights, LED foot well lights,HCF mod, fumoto f-103 oil valve, anytime backup-camera mod.
kevinpt is offline   Reply With QuoteReply With Quote
Old 10-04-2013, 09:32 AM #2
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
.................nice mod
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
2019 v6 galactic grey 4wd trd offroad 4runner
Last edited by earthrealm; 10-05-2013 at 11:00 AM. Reason: seen what i was looking 4
earthrealm is offline   Reply With QuoteReply With Quote
Old 10-04-2013, 06:19 PM #3
kevinpt's Avatar
kevinpt's Avatar
Originally Posted by earthrealm View Post
more pics please.................nice mod
what would you like pictures of?
nice thing about this mod is drinks stay in low 30's and i think if you insulate you might get stuff to freeze. cheaper then arb fridge
Old 10-06-2013, 08:28 PM #4
A/V1's Avatar
A/V1 A/V1 is offline
Real Name: Brad
A/V1 is on a distinguished road
A/V1's Avatar
Real Name: Brad
Interesting mod. However only problem with it is You need to keep the A/C going to keep the compartment cold.
You can actually make your center console a cooler by installing thermo-electric devices, which are fairly cheap, and easier to control.
Peltier Thermo-Electric Cooling Module 6 Amp 320-253
Vehicle: Black 2003 T4R Limited V8 4WD Mods & Equipment: Hail Damage; Kenwood DDX573BH/ rear camera; GX470 Overhead; DC power, A/V aux jacks, & USB plug inside center console box; DAC switch relocate; Interior LED swap; Footwell LED lighting; Muth heated signal mirrors, LED tails, & Valor exhaust tip.
Support our troops!
A/V1 is offline   Reply With QuoteReply With Quote
Old 10-06-2013, 08:36 PM #5
zopperman's Avatar
zopperman zopperman is offline
Moderator
Real Name: Zak
zopperman is on a distinguished road
Moderator
zopperman's Avatar
Real Name: Zak
Can you elaborate? this would be sweet in the bottom of a cup holder.
edit, looks like it needs a heat sink which would be a PITA under the cup holder, too much cutting
zopperman is offline   Reply With QuoteReply With Quote
Old 10-06-2013, 10:08 PM #6
kevinpt's Avatar
kevinpt's Avatar
yes i could do this but my mod was less then half that cost so thats what i did
Old 10-06-2013, 10:25 PM #7
mikebontoft's Avatar
mikebontoft mikebontoft is offline
mikebontoft is on a distinguished road
Wholly crap, that's brilliant!
'94 SR5 V6, 2" body lift, 4.56 gears, 31x10.50-15, Hella 500's (needs less stock!)
Originally Posted by KidVermicious View Post
I wouldn't be opposed. With another kid on the way, four doors is looking more and more attractive.
mikebontoft is offline   Reply With QuoteReply With Quote
Old 10-06-2013, 10:27 PM #8
kevinpt's Avatar
kevinpt's Avatar
so what would you do about the heat from one of these? you could not have both in the console
Old 10-06-2013, 11:45 PM #9
LTDSC's Avatar
LTDSC LTDSC is offline
Real Name: Sam
LTDSC will become famous soon enough LTDSC will become famous soon enough
LTDSC's Avatar
Real Name: Sam
GET OUT OF MY HEAD. I've been thinking about doing this and routing to the cup holders. Nice mod.
LTDSC is offline   Reply With QuoteReply With Quote
Old 10-07-2013, 12:04 AM #10
kevinpt's Avatar
kevinpt's Avatar
its an easy cheap mod and could be done with the cup holders. fir that i would use tubes to each side of the cup holders
i also get a lot of questions about it when i have people in my truck. fun to tell people that not only do you have heated seats but you can cool drinks
Old 10-07-2013, 12:05 AM #11
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
thats what i was thinking, should be easy because the vent tubing is right there. could easily make it slide into that tubing.
Old 10-07-2013, 12:54 AM #12
kevinpt's Avatar
kevinpt's Avatar
do it
Old 10-22-2013, 02:25 AM #13
810moto's Avatar
810moto 810moto is offline
810moto is on a distinguished road
810moto's Avatar
I'm really confused on this. Is there a pic from further back? Can't tell where this is.
2004 SR5 2WD,285/75 Nittos,RB-1.5"BL,K&N drop in,LED interior Ltg,12v mod,Debadge,Daystar lights,Optronics rear lights,FJ swap,Fog Light mod, All-Weather mats,ES swaybar bushings & end links,Spidertraxx,HCF delete,1/2" toytec spacer,2custom cargoboxes
810moto is offline   Reply With QuoteReply With Quote
Old 11-19-2013, 10:52 PM #14
kevinpt's Avatar
kevinpt's Avatar
its the back wall of the center console
Old 11-20-2013, 12:06 AM #15
zopperman's Avatar
Moderator
Real Name: Zak
Moderator
zopperman's Avatar
Real Name: Zak
Instead of removing the whole console couldnt you just pop the back off and access the AC duct from there and drill into the back?
WTB: 4th GEN CONSOLE LID pearlj10 Want to Buy/Trade 0 07-13-2013 05:23 PM
4runner reading map light + roof console Overhead console nissanh For Sale: T4R Items 1 04-04-2013 08:10 PM
Anyone looking to to the console mod? dgoll75 3rd gen T4Rs 1 02-11-2012 08:36 PM
Gun console cj80cruiser 3rd gen T4Rs 39 08-30-2010 09:34 PM
99 console into a 98...? daytonaSURF 3rd gen T4Rs 5 01-10-2005 12:23 PM
