New Limited OEM Wheels - Should I buy?
jschrumm
Hi Guys,
My 18" limited wheels are toast. They have been slowly bubbling and chipping and its to the point where its really getting bad. I reached out to a local (MA) wheel shop, RimPro, and was told they are too far gone to refinish. They wouldn't be able to repair the corrosion or warranty their work. So I am faced with buying a new set. I have looked at a bunch of wheels but still think the originals look great. The question is, if I buy a new set of OEM rims to replace mine, will I be fighting this corrosion issue again in a few years? Anybody else replace with aftermarket OEM wheels? Not sure if I got a bad batch or if they are all like this. Appreciate your comments.
the wheels you get are up to you... but yeah the new ones you buy will do the same thing... my wife's runner has small spots of this happening on a few of them (When we bought it two years ago (07) and I polished and waxed the crap out of them when to stem the tide, and it's really done just that) .
I would say if you go with OEM replacement wheels wax them to protect the paint real good twice a year (wheels are gonna chip and that's how the pitting starts on a painted wheel if left unprotected)... or powdercoat the wheels before installing them.... thought about sanding your existing ones down and then plastidipping them? it's another option
If my wife's ever look like yours I'm gonna take them off and get them powdercoated a gunmetal color...
good luck
Wife just got an 2006 T4R Limited where the wheels are bubbling a bit, I plan on refinishing them myself cheaper than OEM cost. :)
Thanks for the feedback. I reached out to a powder coating shop and looked into plasti dip. Interesting stuff. If I go the new OEM route, I am definitely coating them before mounting. Hopefully I can salvage the exiting ones, seems like such a waste to scrap them.
If you had them sandblasted and powder-coated a darker color, they would completely transform the look of your 4Runner. Just for reference… the shops in my area charge anywhere from $55-70 per wheel.
Give the plastidip a shot
I think with a little prep you would be really pleased with the results. I have the same wheels and dipped them anthracite gray a while back. Mine weren't as corroded, just a few spots where the clear coat was failing. I just feathered the edges in those spots, washed really well with degreaser and sprayed away once completely dry. The dip has a little texture to it and is matte so I think the corrosion would be pretty well hidden.
I've been surprised by the number of compliments I get. People can't believe it was so cheap and easy.
Here is my conversation with a NH based powder coating shop:
Hi Jesse,
I am interested in getting my 18" 4runner OEM wheels powder coated. I was told by another vendor that the corrosion was so pervasive that refinishing would not be possible - there would still be damage and they would not be able to guarantee their work. I am not sure if that was powder coating or just repainting. Can you please take a look at the attached pics and let me know if kwick silver would be able to help? How much does it cost per wheel? How long do you guarantee the finish? Where would the work be done and how long should I expect to have to leave the vehicle?
Thanks for sending over the pictures... the issues you're having with these are fairly common on Toyotas and we do a lot of these for the Toyota service departments.
The other vendor you spoke with was correct in saying that applying a new finish to what's there won't resolve the problem. The only way to remedy the issues with the finish would be to strip the wheels completely first. We would need the rims bare, so you could either have the tires and sensors removed and drop off the bare rims or you could simply drop off the vehicle and we could take care of that for you.
Once the rims are bare, they are chemically stripped in a non-corrosive strip tank, then blasted to remove any remaining corrosion. The wheels are then baked with a powder coated primer, cooled, and then the new finish is applied. At this point, you have the option to refinish them in the factory color, black or some other finish you may prefer. There is no additional charge for a color we already have in stock. The rims are then baked with a powder coated primer, allowed to cool and then the tires are remounted and balanced.
The overall process takes 3-4 days and runs $175-200/wheel, depending on how the wheels are provided to us and whether we would be required to dismount/mount and balance as well as remove and install the sensors. On a side note, since the process requires the tires be removed, it is a good opportunity to do tires if they are getting low and I provide my special wholesale pricing as a thank you for using us for your repair as part of the deal, if you need them. I find a lot of customers need them anyways, and the savings on the tires helps to offset the cost of the repair by usually a couple hundred dollars.
Jesse, thank you for your quick response. The price quoted is roughly the same as the replacement value (although it does not include labor), however my concern with replacing OEM wheels is that the new ones will just do the same thing in a few years. As you noted, it's a known issue with painted Toyota wheels. I assume powder coating is a much more durable solution. Is there any sort of guarantee/warranty on your work?
Just to clarify, it would be about 200 if I just brought in the truck and dropped it off instead of giving you the wheels already dismounted? I would like to go back to the factory color or as close to it as possible. What is the fee if you don't have it in stock?
That's exactly right, even if you went to buy brand new ones from the dealer, (which are usually $300-600/rim) they would just do the same thing in time.
The cost would be $200/rim if you dropped off the car and let us take care of everything. There is a one year limited warranty on the finish. It obvious does not cover curb damage or things of that nature.
There would be no additional charge for that color. Since it does take a few days to do, I usually recommend dropping off early in the week, Tuesday being the latest.
try a place in Peabody, ma called Wheel repair Specialists. they are on rt 1 south in Peabody right at the jughandle about 4 buildings down from the cabaret lounge.
a lot of dealers (herb chambers, bmw of Peabody etc)use them and we have used them a few times for work. IIRC they charge 125.00 per rim. check them out it might work for you.
That seems a bit high to have them re-finished..but midwest vs east coast..
My wheels are looking like yours as well, mine are the 17" sport wheels. If I had the 18" limited like yours, I'd have them re-finished. I like that wheel, I do not like the sport wheel..So I ordered a new set of TRD Pro wheels off ebay for 800 shipped.
Unless you are going to get them refinished and make them look like a new set of OEM wheels I would just buy a new set of wheels. No point in paying this much if you're not trying to stay OEM, at least I think.
I suggest you browse around for some wheels and see if you find anything you like, because I know i'd be pissed if I paid ~200/wheel and later came across a cheaper wheel i would have liked instead.
buy new wheels and tires and dump these on craigslist for $3-400 if the tires are bad, 6-700 if the tires are cool. or dump the wheels for $200-300 and see what you get.. everyone is happy.
inscarguy - response from Wheel Repair Specialists below:
The corrosion is problem with the metal. Refinishing your wheels could be a waste of money. We have tried refinishing this type wheel several times with no success the corrosion returns.
Maybe you should consider purchasing new wheels.
Sorry
____________________
i do like the OEM rims, but don't want to just get new ones as the same problem will likely occur. looking into other powder coating shops.
