Windshield washer pump is hummin but no ouput
swapmeet
I tried the search function, but all the results were related to the pump not operating. I can hear the the pump...... pumping? But there is no output.
Obviously nothing is frozen, it's 83* here.
Any suggestions?
*edit* So I just went out and poked at it with a stick. Managed to break one of the washer lines close to the pump. Since it was draining out, I hit the washer on the stalk and it shot out. So I'm guessing the line is clogged. I'm going to replace and rebuild the line. #answeringyourownquestions
I have had washer hose lines become stopped up,and I have a small hose connection device to flush them out.
Many times it's the small outlet points, near the windshield that are stopped up also.
This might or might not not be your washer problem.
Eureaka!
So broke a fitting fiddling with the hoses. I replace said fitting, and try washer with the hood up. It works. "yay!" I say...
Then I put the hood down and try to wash my windshield... no workie....
I'm like...
So I pop the hood, mess with the hose location and whammo... it works. Nothing like something stupid being the problem.
But hey! It works and maybe this little nugget will help someone else down the road!
Thanks everyone for following along!
seltzernator
