Rotten egg smell = bad Cat?
ccvortex
Getting on the freeway or any substantial acceleration causes a terrible rotten egg smell to come in the back window; does this basically automatically mean bad cat?
That is a very good question. I have always noticed it with our Toyotas or if you get behind one on the freeway. Pewww.
What if you remove the cats, as in doing long tube headers and aftermarket y pipe. Would it still smell? Would it be worse?
I am assuming the smell is coming from the cats themselves so someone correct me if I am wrong, but converting to a straight exhaust system would eliminate that... but wouldn't that mess up your fuel mix ratio because the computer could no longer measure exhaust gases?
rotten egg smell = you're doing it right
When I have the back window down I usually will smell it at 2/3 throttle or above.
I have dual side exit exhaust also so that does not make a difference.
I've never noticed a rotten smell in any of my family's Toyota's or any vehicle for that matter. It only happens when you roll down the windows? I've only noticed when you first start up in a garage or without wind you can catch a wiff of a "rich" burn. Never smelled rotten to me just seemed like a normal part of the combustion process.
My 4.0 4runner gives off the smell, but my 4.0 Tacoma doesn't or at least I've never noticed it. Tacoma is a side exhaust and the rear window isn't as big.
It's the smell of sulfur.......its from your exhaust. Due to air flow and vacuums the fumes from exhaust get caught and pulled into the cabin when the rear window is down.
Fixes:
don't roll down back window
don't accelerate quickly
modify exhaust to exist side of vehicle behind tire instead of directly out the rear.
I just sold my Jeep a month ago to get something more reliable and my obvious choice was a 4runner mainly because of the rear window drop. The fumes only occur when I floor it so I usually roll the window up before I do. But I'd like to avoid that PITA.
Could putting a downward exiting exhaust tip help? Seems like a side exit may screw with the pipe mounts. I've also seen I can cut it right before the bend in the axle. Does this cause any problems in the future? Does having the fumes exit directly under the vehicle have any affects inside the cabin?
My '04 back in 2004! - cut the resonator off and pipe exits downwards before the rear axle = no smell of eggs :)
My 2007 5.7 Tundra has a strong smell yet neither of our 4runners have any. I drive the Tundra very little. I don't know if maybe that makes any difference or not.
chasebradshaw
