03-06 Headlight Swap Help
Status
Not open for further replies.
BusinessHippieRH
Here goes:
I did the 03 to 06 headlight swap on my 4R this morning. Having issues where only one side works. I wired up driver side first, and DRL and turn worked great. Wired up passenger side, and drivers side quit working...
Bulbs:
LED 168A for DRL
LED 1156 for turn
Both are Sylvana
Wiring: removed stock turn signals harness (in the bumper as I'm building my own and this was my main reason for the swap). Removed stock DRL harness. Spliced red to red, green to green. However, white with black stripe needed to be accounted for from both harnesses. I assume this is ground. I simply wired together both and the new harness white w/ black.
Any help would be greatly appreciated. Thanks!
So: problem solved... -ish. Non function on driver side was due to loose connection. However, I have a new odd one.
I have hyper-flash on driver side only. When I put hazards on, they blink correctly (synced, etc). I do still have stock bulbs in my tail lights. Do y'all think this could be the problem?
Status
charlesz
