indy084rnr
Hello all,
I've done quite a bit of research on this and have tried to pull together all the info in to figuring out what the dealio is with my Runner.
I've got an '08 4th Gen that has started making a low reverberation (A low putter) only heard in the cabin, while in gear, and either stopped or just starting to move. Typically cant hear it after acceleration.
I've read that it may be a torque converter, transmission mount, or engine mounts. I haven't seen any movement from any of the mounts. And I'm slowly trying to rule out the torque converter in the cheapest way possible. It honestly had been getting sluggish on the acceleration as well.
I then thought it might just be a clog in the air filters so I changed them. Reverberation continued. I have now shifted to thinking it could be the engine not running at 100%. It is a vehicle with 150,000 miles on it so I added some fuel system cleaner (Liqui Moly 2007 Jectron Gasoline fuel injector cleaner) and I'm doing a spark plug change this weekend.
Do you folks have any idea what this could be? Any experiences that could point me in the right direction? Anything helps and I appreciate everyones time.
