ABS Wheel Speed Sensor - Rear Harness
joemaritime28
I have multiple dash indicator lights that have come on. ABS, VSC, Traction control and check engine light. They have been on for awhile now, but when I rotated my tires the other day, they shut off and stayed off for a day or two.
Is this most likely the ABS Wheel Speed Sensor? And is there only two sensors, rear and front?
There is a sensor on each wheel. I had this problem before and using techstream I narrowed it down to a broken connection before the harness. Crimped in new wire and all has been well since.
if you have the $20 bluetooth scanner, it can still pinpoint the specific wheel abs that may be bad. download the app MOTORDATA from playstore, and pay a lil extra for extended feautures. i had similar problem a couple of months ago. resolved
if you have the $20 bluetooth scanner, it can still pinpoint the specific wheel abs that may be bad. download the app MOODATA from playstore, and pay a lil extra for extended feautures. i had similar problem a couple of months ago. resolved
For the app you're suggesting, I'm assuming you're referring to Google Play Store(?), if so i when there and couldn't find the app you mentioned, I could only find "MotorData" and "Motolink", these are the only two apps that are even close to...MOODATA, if you would could you clarify or even better post a link to the app?
