07-19-2020, 06:35 AM
Real Name: Jeremy
Real Name: Jeremy
Broken icons
Anyone ever see/hear of this happening? Less then 3k miles on them! Rear shocks.
2007 4Runner Sport 4x4
CoastalOffroad-Smittybilt-4xInnovation-RCI-BajaRack-SPC-ICON-Nitro4.88-EatonElocker-CVJ--PolyPerformance-Method-MickeyThompson⁹-AFE-Urd-Gibson-SprintBooster-Weathertech-Pioneer-Infinity-DiodeDynamics-OPT7-HiLift-Coverking
Build thread:
https://www.toyota-4runner.org/4th-g...ort-build.html
07-19-2020, 01:01 PM
WTF!! Never seen that. That's wild. Hit up Icon and report back on what they say.
Sent from my SM-G986U using Tapatalk
07-20-2020, 08:52 AM
Real Name: Aaron
Real Name: Aaron
Yikes. I'm assuming that's a 2.5" with resi too?
2007 4Runner Limited V8
| 2.5 Fox 3" lift w/ remotes & DSC | Dobinson 677V rear | SPC UCAs | 1" BL | SCS F5 | 315/70 DuraTracs | Prinsu full rack | RLC rear bumper/swingout | C4 front bumper | Warn VR8-S | F55 fairlead/Flatlink-E | Rocksteady skids | ARB 2500 awning | Dometic CFX 40W | Partner Steel 22" stove | Adventure Index drawer/sleeping platform | ARB twin compressor | Odyssey 34R dual batteries | Blue Sea SI ACR/fuse panel/USB | Renogy 100W Eclipse | Baja Designs Squadron R & S2 | G5R retrofits | Doug Thorley headers/Y pipe | weBoost OTR |
07-20-2020, 10:51 AM
Real Name: Joe
Real Name: Joe
Do you have any correction on your panhard bar? I kind of think you would be getting excessive side shear load on the shock there if you have a lift more than 3" and no correction.
2015 T4R Trail Red, 3” lift, 285s, Niserack, HF rock sliders, BA bumper
2006 4runner sport, v6, Tacoma TRD springs front, airbags And 2” spacers in rear. 440k and still chuggin along.
1977 FJ40, V8, lifted, Warn 8274 winch etc.
2006 GX470, 285s, 2” lift, C4lo sliders
08-18-2020, 12:20 AM
Real Name: Jeremy
Real Name: Jeremy
I have adjustable panhard and the lift bracket.
2.5 CDC resi's
FIXED
Warranty fix by Icon
I added Limit straps to keep from loading the shock
Build thread:
08-18-2020, 12:48 AM
Stock bumpstops?
07 SR5 4x4
08-18-2020, 01:20 AM
Real Name: Jeremy
Real Name: Jeremy
No, wheelers super bumps. Bump only work for compression. During droop all the axle weight is supported by those 2 small top hat mount studs
Originally Posted by originalg00kster
Stock bumpstops?
Build thread:
08-18-2020, 12:43 PM
It could be from the black threaded top cap on the shock coming into contact with the frame when drooping out, I'm pretty sure mine have some rub marks there, also 2.5" Icon shocks.
This would bind the threaded stud against the frame and potentially snap it.
I remember this happening to someone else on the forum and that was their conclusion. I find it a little hard to believe that the axle 'dropout' force alone would snap the threads as the upper mount bushings flex a little during something like this and take some of the initial force. Especially if you haven't been jumping your truck, but I could be wrong.
08-18-2020, 12:57 PM
Real Name: Jeremy
Real Name: Jeremy
Nothing snapped. The stud ripped from the aluminum top hat, thus stripping the top hat. 3-4 threads into aluminum is not much to support a entire axle with 35s.
Build thread:
08-18-2020, 01:00 PM
Real Name: Jeremy
Real Name: Jeremy
See pic
Build thread:
08-18-2020, 04:20 PM
See pic
That's wild!
08-18-2020, 07:53 PM
What length shock?
08-18-2020, 09:38 PM
Real Name: Brett
Real Name: Brett
I've heard of people breaking ICONs, mostly after a lot of abuse, but never seen it documented or even heard of this type of breakage. That stripped out cap would give me pause for sure. They need to reevaluate that design imho.
1988 DLX 22RE AUTO BLACK- "Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
08-18-2020, 11:19 PM
Real Name: Jeremy
Real Name: Jeremy
Ive heard of this exact same problem with other name brand shocks too though.
Build thread:
08-19-2020, 09:40 PM
The coil on my coilovers snapped at the base after two years, but I think I am to blame for not washing them enough in the winter, might have too much preload, and need the 700 springs for my bumper winch setup.
